THE place to get pizza...here anyways
http://www.bellystakenbake.com/?page_id=4
Fenlason wrote:well I have my sacrificial pieces put on top of my plates at the door ways. [tractor chains might chew them up]and placed crusher dust. sloped up to it on both sides.. and did some other raking around the area.. [fresh gravel]
It has gotten quite windy.. from the south. I think tomorrow we are getting Kerry's rain. Because of the wind.. I guess we might mountain bike.. I might take the big bike our.. and do loops.. down my big scarey hill.. and back up around.. again and again.. I will perhaps get better at the downhill... and pedaling the big bike back up around.. will be a work out.![]()
I might we we are big helmet and armor...
hotrod wrote:Fenlason wrote:well I have my sacrificial pieces put on top of my plates at the door ways. [tractor chains might chew them up]and placed crusher dust. sloped up to it on both sides.. and did some other raking around the area.. [fresh gravel]
Fenlason wrote:hotrod wrote:Fenlason wrote:well I have my sacrificial pieces put on top of my plates at the door ways. [tractor chains might chew them up]and placed crusher dust. sloped up to it on both sides.. and did some other raking around the area.. [fresh gravel]
I might doodoo here in a bit...![]()
Fenlason wrote:
my new shelter.. a few weeks ago.. this place had some trees.. and a bunch of junk.. and was about 2 1/2 feet lower than it is.
hotrod wrote:now if a guy could spray it with quick dry cement on the outside to keep it really rigid and nearly iondestructible then spray on insulation on the inside...![]()
Fenlason wrote:hotrod wrote:now if a guy could spray it with quick dry cement on the outside to keep it really rigid and nearly iondestructible then spray on insulation on the inside...![]()
that would be great...![]()
except then they would probably charge you property tax..
actually if you did it right.. painted it green again.. and put the logo back on.. maybe they would not notice..
hotrod wrote:Fenlason wrote:hotrod wrote:now if a guy could spray it with quick dry cement on the outside to keep it really rigid and nearly iondestructible then spray on insulation on the inside...![]()
lololol your a deviant....
