schaney wrote:Larry,What brand of epoxy do you use?
musicman wrote:Mornin' all, I'm a little confused now. All plywood should be sealed with epoxy especially the edges. But glue won't stick. So should I wait until things are together before using the epoxy? Won't this leave some edges uncovered? John
schaney wrote:West Systems has worked fine for me for many year. The reason I first started using it was availability. Three places with in 30 miles stock it. When you added shipping, most other brands ended up costing more.
afreegreek wrote:epoxy manufacturers spend plenty of time and effort ($$$) to give you the best possible results at 70 degrees.. mucking about with temperature is not usually going to improve the result by much if at all.. if your room, work piece, and resin are at 70 degrees, that's about perfect..
