Heating help
Heating help
Postby ki4eit » Thu Feb 24, 2005 5:19 pm
I was just going to buy a regular old small plug in heater to sit on the shelf. But i read ez to burn stuff, i know from experiense that its hot to touch (dont ask) .................. But furnace. Whats that where do i get 1 do i have to run a chimney. whats it run off of, or is there something even better to use then that.
ki4eit
Postby mikeschn » Thu Feb 24, 2005 5:36 pm
I really like the forced air furnace... I buy mine at ducktec.com
http://www.ducktec.com./itmidx14.htm
I plan on mounting it like this in the Lil Diner...
Postby mikeschn » Mon Jan 02, 2006 9:40 am
Okay,
Here is the furnace mounted...
Postby mikeschn » Mon Jan 02, 2006 9:41 am
Here I've added the elbow. It directs heat into the cabin quite nicely. It also warms up the cabin quickly... within minutes...
Postby mikeschn » Mon Jan 02, 2006 9:42 am
And here is the finished result...
Postby mikeschn » Mon Jan 02, 2006 1:25 pm
powderburn wrote:Mike
The link didnt work for me.I'd like to see a few specs (size BTU gas valve amperage and CFM)
Thats a pretty nice set up.How much noise does it make?
That's strange... it worked for me....
Here, I'll paste the picture of that page here...
As for the noise level, it's very quiet. You could compare it to a small fan or a small hepa filter...
Postby mikeschn » Mon Jan 02, 2006 2:04 pm
powderburn wrote:Thanks Mike
Looks sweet!!!
No chance for you freezing to death...LMAO!!!
hhhhmmmm
Now the link is working? It was giving me an "internal error" page the first time I tried it. :?
Im assuming you purchased the smallest model? Should run about 10 minutes per hour even on the coldest nights. :thumbsup:
Yep I bought the smallest one... 12,000 btu...
I figure as long as I have propane and a solar panel to keep my battery charge, I can stay warm.
Q can tell you how long a small bottle of propane lasts...
Let me do a search and see if I can find that...
Okay, here is Q's message... he says he has a 5 gallon propane tank. I don't know how much that is relative to a 5# or 20# bottle...
http://tnttt.com/viewto ... 8334#48334
Postby WarPony » Mon Jan 02, 2006 3:07 pm
Mike, does it look like you can mount one of these vertically or will the regualtor be at a goofy angle?
WarPony
Images: 289
Postby Greg M » Mon Jan 02, 2006 5:12 pm
Mike,
What are the dimensions of the cabinet you put the heater in? Is the small grille in the long side the cold air intake? What type of fan does the furnace use to move the air around, bladed or squirell cage? I'm trying to think of how small a space it could be housed in and still be able to draw air through it.
-Greg
mikeschn wrote:Okay,
Greg M
*Geek Extraordinaire
Images: 85
Postby critter » Mon Jan 02, 2006 5:20 pm
hey all,
i have a furnace sorta like that one in my pop up and it works great but i also use a mr buddy heater 79$ and like it very much.its what ill use in my tear as its portable and safe.just my opinon whats yours?
critter
critter
critter
Images: 54
Postby WarPony » Mon Jan 02, 2006 6:24 pm
Critter, I wanted to use a Mr. Buddy-type heater at first but after getting the crap scared out of me with all the talk about carbon monoxide poisoning, I'll probably go ahead and make a life investment and cough up for the Atwood heater if it will work in my TTT. If it doesn't, I'll go without and use extra blankets or a heated mattress pad. I wouldn't want a Mr. Buddy to make me Mr. Deady.
WarPony
Images: 289
Postby mikeschn » Mon Jan 02, 2006 7:42 pm
WarPony wrote:Mike, does it look like you can mount one of these vertically or will the regualtor be at a goofy angle?
That's a tough question...
I never thought to mount it vertically... you would have to have a 90* on the exhaust and a 90* on the duct...
I suppose we could email ductek...
Postby mikeschn » Mon Jan 02, 2006 7:51 pm
My enclosure is 29" x 13".,
But if you want to minimize the distance between the fan and the back wall, the manual says the minimum required distance is 1 3/4". Let me know if you need a pdf of that manual...
Greg M wrote:Mike,
-Greg
Postby mikeschn » Mon Jan 02, 2006 7:55 pm
critter wrote:hey all,
I won't use anything that emits carbon monoxide inside the trailer, or depletes oxygen inside the trailer...
wanna know why?
http://www.cdc.gov/mmwr/preview/mmwrhtml/mm4832a1.htm
http://doityourself.com/info/carbonmonoxidecampin.htm
and
http://www.cpsc.gov/cpscpub/pubs/5008.html
So I ask you this... is it worth saving a few bucks to shorten your life?
Postby critter » Mon Jan 02, 2006 8:10 pm
hey all,
well i guess my daddy was right.. he always said boy iffan your gonna be dumb you gotta be tough.no relly i turn the thing off before i go to sleep and it supposed to be safe to use in a tent i think.maybe i need to do more research. id hate to wake up dead one morning! :thumbsup:
critter
critter
critter
Images: 54
