Oasis Maker wrote:Nathan, that's a fantastic application and your Lowe's find is like gold! I used what I already had inherited with the mounting brackets that came with my AutoUmbrella's, and although it's rock solid, no doubt it is also heavy.
Your idea opens up a new and simple modification that I will certainly explore. As Slowcowboy said, it will be nice to do away with the canopy clamps, and for me, my AutoUmbrella poles. My current set up is rock solid in very high winds, and with the wood block under the clamps, the unit tightens securely as it would on the underside of a picnic table... but I think it is a bit overkill.
I've pulled up the Lowe's page for the brackets you are using. Did you do the angle welds yourself? Because I can barely see your weld lines if you did... well done. I'll check back later.
Scott G.
Oasis Maker wrote:Hey Nathan, just curious as to why not one 90 degree weld vs. two 45's? Was strength a concern or aesthetics?
Scott G.
Nathan N wrote:
Nathan N wrote:Slowcowboy,
You sure do have the worst luck. I've not camped in Colorado enduring a freak wind gusts, experienced any strong Santa Ana winds, or never have had the pleasure of ocean front winds with our setup.
In my experience I figured it was rather secure against winds. I mean as compared to an first-up type shelter. If the mounts are solid the nylon would flap but I would never have bet on the total destruction you are describing.
We did experience an issue with heavy rains at Spring Mill in Indiana last May. Here is a photo from Saturday morning - I almost didn't get the door open. I apologize for the poor photo as it was rather early and it is from my phone.
This just shows one side but both sides held about an equal amount of water. I would guess about five gallons on each side of the main support pole. That is a lot of weight. You can see the rods are bowed downward due to the weight. They never disintegrated nor did the plastic bits fly all apart.
I haven't come up with a solution to this problem yet - perhaps some fiberglass poles to get an arch upwards so the rain would drain over the horizontal rails.
One difference may be that on our trailer the supports are right at the ends of the shelter - 10 foot trailer with the supports about 4 inches from the ends.
Just the darnedest luck I tell you!
Nathan
Oasis Maker wrote:
Wow Nathan, that sucks... (no pun intended). We have a different set up, but I control the rain by just dropping the one side lower into the wind. I've only been in a few downpours, but with the canopy tilted down into the wind, it's impossible to collect water.
It looks like your canopy runs flush, almost resting on the top and full length of your trailer. I can see how water would collect like that. Do you have any more play in your brackets to raise one side higher?
Scott
slowcowboy wrote:It flops around a lot on the brakets nathon recomened. and I DID have it all straped down with bungee cords to my roof rack.
Slowcowboy.
Users browsing this forum: Bing [Bot] and 12 guests
