hmm I forget what day.. I did cut. split and stack about 2 cords of firewood.
hmm I think it was late Sunday we did do a mountain bike ride. I took the inefficient Enduro out. I did my downhill loop again, this time with a cycle computor. My first run was 11mph. Not fast for a downhill you say? It is steep and loose.. Originally we were crawling very slowly down it... only 3 others have tried it.. and none successfully made it. If there was a better runout at the bottom, perhaps it would be easier to let it roll.
My second run 11.6..
My 3rd run.. 14.3.
One of my runs.. a little to much front brake.. and the back end came up.. and started trying to pass the front.
I had some runs back into the 11's.. some in the 12's. I did lengthen the fork back out, which made the bike tougher to get through the single track.. but more stable on the downhill. I did some run's in the upper 13's that actually felt slow.
I decided to try the slow twisty line down the hill again. I made it, and felt comfortable. I thought I would try one more run.. again on the twisty.. and messed up and had to put a foot down. I did not want to end on a failure... so back up again. and again I was successful 11 out of 12 runs..
