Is that your final answer?
Postby mikeschn » Fri Sep 03, 2004 6:58 pm
Yes, this is my final answer. This is how the cabinet and the galley will be laid out. Furnace will be on the left (not visible in the photo), and a/c will be on the floor. There's lots of room for the feet, and plenty of storage too.
Now, if I've forgotten anything, this is the time to tell me!!! :D
Postby BufordT » Fri Sep 03, 2004 7:09 pm
Wise decision. Your learning. One of these days you'll learn to listen to me.
Bufordt :twisted:
"RUSH" The Man, The Legend, The Way Of Life.
BufordT
2nd Teardrop Club
Images: 23
Re: Is that your final answer?
Postby Eric Adams » Fri Sep 03, 2004 7:18 pm
mikeschn wrote:Image
I must be missing something, from the 2 pics I don't see the vents for the AC unit.
BTW: I have a AC I am fidling with putting on my trailer now that I am going the 1800# trailer route. I figure I'll finish and it'll be code out though.
Eric Adams
Postby Arne » Fri Sep 03, 2004 7:25 pm
a/c on the floor at back with a vent sounds..... 'kool'. Instead of a louvered vent, could just have a solid cover, removable when needed. I'm liking this idea (the a/c on the floor at the back, that is).
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Eric Adams » Fri Sep 03, 2004 7:28 pm
Mike, what kinda wood is the galley counter made of? I like that grain. I bet with a few coats of spar varnish it'd look real nice! :)
Eric Adams
Postby mikeschn » Fri Sep 03, 2004 7:42 pm
Eric,
That's a pine panel that they sell at Home Depot, in the same aisle as the melamine. They come in 2'x4' or 2'x6' for example. It's a whole lot lighter than plywood, if you're not going to put anything heavy on it, otherwise you'll need to re-inforce it. I'll be reinforcing it...
Postby mikeschn » Fri Sep 03, 2004 7:58 pm
BufordT wrote:You're learning. One of these days you'll learn to listen to me.
Bufordt :twisted:
Buford,
I had to evaluate all the options to make sure the first time builder was getting the best design possible, and one that was easy to build... :wink:
Postby BufordT » Fri Sep 03, 2004 8:46 pm
Bufordt :twisted:
Buford,
And a mighty fine job you are doing.
Keep up the good work.
Bufordt
P.S. printed out the 7ft weekender.
I'll keep you posted.
BufordT
2nd Teardrop Club
Images: 23
Postby mikeschn » Sat Sep 04, 2004 9:48 am
I got the upper galley shelf in this morning too! It'll be looking like this...
And I'm even toying with the idea of mini spindles back there too!!! :D
Postby Guest » Sat Sep 04, 2004 1:12 pm
What about the beveled mirror?
Guest
Postby mikeschn » Sat Sep 04, 2004 1:31 pm
Yep, that'll be on the inside... I didn't buy it yet... and it may not be beveled!!!
