Sharon,
You are building a beautiful project!!! The attention to detail is amazing!
There is so much on this sight that I have a hard time covering it all and I am sorry that I just found your build link. Great job!
Rod
You took physics and/or mechanical engineering, didn't you?
The load on the hinge or on the lifting mechanism at the opposite end is a simple calculation. Think of the roof as a beam with uniformly distributed weight. The force at either end is one-half the weight of the roof.
If the center of gravity of the roof is skewed forward, for example, to a point where the distance between the hinge and the center of gravity is three-quarters of the distance between the hinge and the lifting attachment at the opposite end, then the force needed to lift the roof is three times greater than at the hinge.
The force needed at the hinge is a function of the center of gravity relative to the two ends of the roof. It does not change with the angle of the roof, because the relative position of the center of gravity changes proportionately with angle of elevation.
FYI, fiberglass mat is stronger than fiberglass cloth by thickness because of the random cross-lay of the strands.
To clean it up, press down the strands sticking up, you can heavy plastic sheet/garbage bag sprayed with WD40 and apply pressure with a narrow foam roller. If you also use a narrow foam roller to apply epoxy to fiberglass mat it doesn't get all over the fabricator/applier, just the applicator.
SO.....hundred degree weather again. Epoxy, paint, caulking and glue love that.
When will the trailer be finished?
I'm working on the Round Tail every afternoon lately.
Let's race. I'll be finished with it by the end of October. GO!
What do you suggest be used to remove the WD-40 so the paint will stick afterwards? How do you know you have gotten that WD-40 oil off all the intricate edges?
FYI, neither of us is the hare nor the tortoise. I'm so lethargic and far behind that it's a joke.
