router flush trim bit guestion
Postby LDK » Fri Oct 01, 2010 6:22 am
I have a 1/4 inch masonite pattern for my side profile, what would be the right flush trim bit to use to cut the sides out with. should the pattern be on top or bottom? :thinking:
I have a router but I don't have alot of experience with it. :lol:
LDK
Postby madjack » Fri Oct 01, 2010 6:49 am
...pattern on top...clampit down and use a bottom bearing flush trim bit................................ 8)
p.s. if not very familiar with routers, a bit of practice can save much HEADACHE(and cash) later....mj
Postby Doug B » Fri Oct 01, 2010 7:24 am
uh, Jack, if the pattern is on the top I think you're going to want the bearing on top as well.
Doug B
Postby madjack » Fri Oct 01, 2010 7:41 am
...hold bit by shaft pointing into air...think about it ??????......................... 8)
Postby madjack » Fri Oct 01, 2010 7:55 am
...this is a bottom bearing bit...also know as a pattern following bit............................................. 8)
Postby planovet » Fri Oct 01, 2010 8:24 am
I used this bit and had the pattern on the bottom. Either way would work.
ImageMark (& Cindi)
planovet
The Cat Man
Postby madjack » Fri Oct 01, 2010 8:37 am
...yep Mark, whatever works...the important part is to be confident in your ability with the router...if not, more practice should be done, since a router can do more harm faster, than a sudden sneeze or eye blink..................
madjack 8)
Postby rbeemer » Fri Oct 01, 2010 9:24 am
LDK
Since you do not have a lot of experience with the router. Putting the pattern on top will be easier for you but before you use the route I would trace your pattern on the wood panel then cut it with a jigsaw about a quarter inch away from the line that way when you use the router the amount of wood that you will be taking off will be less and easier to guide the router. DO NOT go in the direction that the bit is turning until you have more experience.
This is just my 2 cents because I do not know your ability and want you to be successful first time out.
Rick
If ducks had scales, would fish quack?
rbeemer
Postby tonyj » Fri Oct 01, 2010 9:31 am
I would bandsaw or jigsaw cut the piece even closer to the line, maybe an 1/8 or 1/16 inch. The less the router bit has to take off, the less of a chance for a little oops.
Once you get the technique down, you'll find lots of uses for shaping pieces using a pattern, or using a pattern cutting bit for trimming up a piece.
tony
tonyj
Images: 160
Postby madjack » Fri Oct 01, 2010 9:50 am
tonyj wrote:I would bandsaw or jigsaw cut the piece even closer to the line, maybe an 1/8 or 1/16 inch. The less the router bit has to take off, the less of a chance for a little oops.
...actually, this is what I do as well, using a jig saw to cut as close as possible before using the pattern/router.....
madjack 8)
Postby aggie79 » Fri Oct 01, 2010 10:47 am
You probably already know these, but, if not, here are a couple of router tips I learned during my build:
1. Spend the money to get carbide tipped bits rather than steel bits.
2. The direction of the cut or the way you move your router is important. A router spins the bits clockwise. You want move the router so that the cut helps "pull" the router to the part being cut. If you're cutting on the outside of the template, then you move your router from left to right.
Re: router flush trim bit guestion
Postby planovet » Fri Oct 01, 2010 11:08 am
LDK wrote:I have a router but I don't have alot of experience with it.
This thread has a lot of good advice for you. Follow it and you should be fine.
planovet: Top or bottom bearing bit, either one will work
madjack: The important part is to be confident in your ability with the router...if not, more practice should be done, since a router can do more harm faster, than a sudden sneeze or eye blink
tonyj: I would bandsaw or jigsaw cut the piece even closer to the line, maybe an 1/8 or 1/16 inch. The less the router bit has to take off, the less of a chance for a little oops.
aggie79: 1. Spend the money to get carbide tipped bits rather than steel bits. 2. The direction of the cut or the way you move your router is important. A router spins the bits clockwise. You want move the router so that the cut helps "pull" the router to the part being cut. If you're cutting on the outside of the template, then you move your router from left to right.
ImageMark (& Cindi)
planovet
The Cat Man
Postby LDK » Fri Oct 01, 2010 7:47 pm
I just want to thank you all for the good advise. It's amazing how much you can learn if you ask questions. :thumbsup:
LDK
