Adding a scooter rack
Postby reddz » Thu Oct 07, 2010 7:28 am
I've bought a 250cc scooter which weighs about 500 lbs. I'm 'pondering' adding a rack on the back of teardrop to carry the scooter. I have 2 X 3 box tubing under the galley door. Any one else done something like this? Any suggestions would be appreciated. Thanks.
reddz
Images: 23
Postby bravebluemice » Thu Oct 07, 2010 4:35 pm
While I don't know much about Teardrops yet, I do know about balancing trailers, and I think your best bet is to build a rack of some sort on the tongue so the weight is suspended between the axle and the tow vehicle.
Five hundred pounds cantilevered out behind you won't tow well, and might give you negative tongue weight.
Good luck, though. Scooters are great additions to camping in general (so much so, I'm building my tear to pull behind my MC).
If I were doing it, I'd build it with just a piece of four inch channel with a hinge on the end across the tongue, another short piece on the hinge for a ramp, and a couple ears on the front and back ends for the strap. If you were clever you could put it right behind the propane tank.
Cheers,
~BBM
Press On Regardless.
bravebluemice
Postby Gage » Thu Oct 07, 2010 5:23 pm
Well, I wouldn't add it to the tongue but don't forget your going to have to add counter weight to the tongue if you do try and add the scooter to the back. In other words, adding 500+ lbs to the back of your teardrop is not a good idea. You need to think this out some more. :thinking:
Image Image Image
Gage
Images: 28
Postby Miriam C. » Thu Oct 07, 2010 10:47 pm
8) If you know exactly how much the scooter weighs it will help your advice. Very few scooters weight 500 pounds...
You will still have to create some tongue weight to add balance...
Postby dakotamouse » Thu Oct 07, 2010 11:54 pm
We put my scooter and the hubby's Honda Shadow in the box of our truck.............not much help if you don't have a truck......but it works for us.
Where did you get it? We didn't get it, we built it!
Myron and Mary
dakotamouse
Titanium Donating Member
Images: 128
Postby Lou Park » Fri Oct 08, 2010 6:06 am
It sounds like you may have to get a rack made just for scooters, bikes, mopeds, that slides into your hitch. Then get a dual hitch extender (harbor freight) to hook both up to. I just hope you have a vehicle that can handle this. I would also be curious if the scooter is small enough to fit inside the camper.
Lou
Lou Park
Images: 5
Postby bobhenry » Fri Oct 08, 2010 6:28 am
Miriam C. wrote:8) If you know exactly how much the scooter weighs it will help your advice. Very few scooters weight 500 pounds...
Honda CN250 Manufacturer Honda
Also called Helix, Fusion, Spazio
Predecessor Honda CH250 Elite 250
Class maxi-scooter
Engine 244 cc (14.9 cu in) liquid-cooled SOHC single cylinder engine
Top speed 72 mph (116 km/h)
Power 19 hp (14.2 kW) @ 7500 rpm
Torque 21 N·m (15.5 ft·lbf) @ 5000 rpm
Transmission V-Matic continuously variable transmission
Suspension Front: trailing link fork
Rear: swingarm
Brakes Front: disc
Rear: drum
Tires Front: 110/100-12
Rear: 120/90-10
Rake, Trail 28°_90 mm (3.5 in)
Wheelbase 1,625 mm (64.0 in)
Dimensions L 2,265 mm (89.2 in)
W 745 mm (29.3 in)
H 1,355 mm (53.3 in)
Seat height 665 mm (26.2 in)
Weight 157 kg (346 lb) (dry)
Fuel capacity 12 L, 3.2 US gallons
The Honda CN250 is a scooter introduced by Honda to the United States market in 1986. It
This one is 350 +/- without fuel ! And it has a 500 cc big brother , the Silverwing Honda Scooter weighs in at 551 pounds.
Postby reddz » Fri Oct 08, 2010 11:54 am
Thanks everyone for the advice. But the paperwork didn't come thru so I won't be getting the scooter after all.
reddz
Images: 23
