http://www.atlanticshed.com/18x23CO.htm
Cliffmeister2000 wrote:Mike, here is an 18" x 23" window made for a shed. It is Jalousie type. 2 of them make a 36" x 23" window, pretty close to your desired size.
S. Heisley wrote::o Wow, Mike! That is one beautiful garage! It's gonna suffer while you're building...wait and see.![]()
I'm curious about that propane tank. Have you weighed it to see what the thing weighs empty? I think the 20 lbs is the weight of the propane that it will hold. I'd like to know what the combination of tank and propane would weigh. Thanks.
myoung wrote:
Here's the fixed-pane front window that will go above the galley on the slanted upper section. It is 30x10-inches nominal.
Cliffmeister2000 wrote:Mike what's going on in the left edge of this window? It looks broken, but I can see reflection in it?
