Which HF trailer......
Postby kelvin51 » Sat Aug 07, 2010 4:23 pm
Im on a budget and looking at the least expensive HF trailer but just curious if it woul be strong enough for a teardrop. Which HF trailer do you guys recommend?
Kelvin
kelvin51
Postby Woodbutcher » Sat Aug 07, 2010 4:29 pm
I bought the larger 4X8, 1750lb trailer from HF. I waited for it to go on sale and I used the 20% off coupon you can always find. It was under 300 bucks. Can't do much better then that.
Woodbutcher
Postby RogHodge » Sat Aug 07, 2010 4:42 pm
Look on Craig’s list- you can find stuff there for next to if not actually free. The smallest capacity 4x8 will only handle around 1000lbs- that ain’t much- but if you want a small trailer it could be enough. I found mine for $50 but I needed to modify it quite a bit. You can see my build log below. In my area there seems to be a lot of the 1500lbs type- it’ s the middle of the road model.
Honestly I think I might go with new if I started all over- instant gratification, and known history- ease of registration etc. is nice. If you look at the HF site you can download the manual for each and make some comparisons- the biggest question you might need to answer is what do I want to build? If you know roughly where you are going it will help you to get there.
For those who would like to have a look I have a build journal and covet your feedback.
http://www.tnttt.com/viewtopic.php?t=33547
RogHodge
Images: 51
Postby wannabefree » Sat Aug 07, 2010 7:52 pm
The cost of my HF 1740# trailer after 6000 miles:
Trailer - $270
New tires - $90
Spare - $50
Replacement lighting - $70
New axle - $240
Total - $720
Cost of custom trailer - ??
If you do go with HF keep a close eye on the tires and axle. We had tread separation and a bent spindle on the last trip. Could have been real bad.
-- Antoine de Saint-Exupery
wannabefree
Images: 82
Re: Which HF trailer......
Postby Larry C » Sun Aug 08, 2010 8:31 am
kelvin51 wrote:Im on a budget and looking at the least expensive HF trailer but just curious if it woul be strong enough for a teardrop. Which HF trailer do you guys recommend?
Kelvin
A lot of builders use the 1195# See the link below. I bought one to use as a utility trailer.
If you have time, keep a constant eye on HF adds and the web site. these trailers are on sale very often. I got mine for $207 after the 20% off coupon which is easy to find.
Last week HF had this same trailer listed at $205 on sale. Plus you could take another 20% off with the coupon. Right now it's at $299.
Keep looking every day, prices change often on these trailers
http://www.harborfreight.com/1195-lb-ca ... ailer-with
Larry C
"If its worth doing it's worth doing Light"
http://www.tnttt.com/viewtopic.php?f=50&t=35852
Larry C
Images: 78
Postby Alphacarina » Mon Aug 09, 2010 5:54 pm
wannabefree wrote:The cost of my HF 1740# trailer after 6000 miles:
Trailer - $270
New tires - $90
Spare - $50
New axle - $240
Total - $720
That mirrors my experience exactly
My axle flexed enough that my tires wore out on the inside edge so I've replaced the axle with a 2,000# one from Northern Tool, complete with new hubs for right at the $240 number. I went to 14 inch car wheels and tires and I added new LED lighting and bought a spare
Unless your project is going to be 750 pounds or less, I wouldn't even look at anything less than the HF 1740 . . . . and if your project is likely to go above 1,000 to 1200 pounds, I'd forget about Harbor Freight all together. My trailer project is 1300 pounds and the best of the HF trailers wasn't enough . . . . wish I had just built from scratch
Don
Alphacarina
Postby boardhead » Thu Aug 12, 2010 2:19 pm
I used the Harbor Freight 90154 trailer. The gross weight of my tear is 750 pounds. I make sure the tires are properly inflated (60 lbs), and have never had a problem with tire or axle wear.
Don't be concerned about the bent up frame in my album pictures, that was caused by being rear-ended. Fortunately, all I had to replace was the HF 90154.
boardhead
Images: 16
Postby eamarquardt » Thu Aug 12, 2010 7:45 pm
I got these prices today from Century Wheel and Rim in Los Angleles:
Ubolts $4.72
Springs $34.81
Hanger kit $8.99
2000# axle $84 or with brakes $182.99
plus roughly 10% sales tax
So (round numbers) $147 w/o brakes $250 w/brakes (tax included) if you picked them up in Montebello (LA) for all new running gear.
24 foot sticks of 2X2x1/8 are about 50 bucks and 20 foot sticks are 42 bucks (tax included). Depending on design you'd need two 24 footers or three 20 footers so no more (worst case) than $130 in steel for a new frame. You'd also need a coupler but they are about $25 bucks or less. Got these prices from Nacho's Ornamental Iron in San Fernando, Ca today.
You can scrounge up a set of rims and tires for probabaly 50 bucks.
2bits set a new standard for a simple but well constructed frame with a minimum of material and cuts.
So, with a bit of effort you can have a brand new, custom built frame for about $450. All you need is to cut about 7 or eight cuts on a band or chop saw and a welder.
If you network around I'm sure you can find someone with the skills and tools. Building a frame would take a morning for someone with a bit of experience.
The two experiences above illustrate my belief that the HF trailers can represent "false economy" in some circumstances.
Cheers,
Gus
eamarquardt
Images: 150
Trailers
Postby hoofhearted » Wed Oct 13, 2010 10:12 am
I'd be interested in a NT or HF trailer only because they come with a VIN# and title. Might save some hassle with the DMV. The trailers/axles can be beefed up easy enough if your tear tends to get a little heavy. I don't know what the bolt pattern is on the wheels but it should'nt be hard to find a 13 or 14 inch rim to mount bigger tires. I'd be a little leary of 12'' inch tires at 65 mph carrying 1,000 pounds on Texas asphalt in the summer.
hoofhearted
Re: Trailers
Postby starleen2 » Wed Oct 13, 2010 10:36 am
hoofhearted wrote:. . . I'd be a little leary of 12'' inch tires at 65 mph carrying 1,000 pounds on Texas asphalt in the summer.
Aw come on - I towed these little beauties on the Hot Texas asphalt at 65 mph with 12" tires just fine. BTW - my frame is TSC 4x8 NF rated to carry 1500 lbs
1060 lbs
950lbs
starleen2
5th Teardrop Club
Re: Trailers
Postby bobhenry » Wed Oct 13, 2010 11:19 am
hoofhearted wrote:I'd be interested in a NT or HF trailer only because they come with a VIN# and title. Might save some hassle with the DMV. The trailers/axles can be beefed up easy enough if your tear tends to get a little heavy. I don't know what the bolt pattern is on the wheels but it should'nt be hard to find a 13 or 14 inch rim to mount bigger tires. I'd be a little leary of 12'' inch tires at 65 mph carrying 1,000 pounds on Texas asphalt in the summer.
Almost all your little trailers are 4 on 4" or 5 on 4 1/2" Make sure the center hub hole will accomidate the center portion of the hub itsself.
I am towing on 12" on the teardrop. The Duro brand tires on the HF are crap ( internal ply seperations) and Duro will not stand behind their product. I replaced all with Carlisle tires and no further problems. I have towed the TD to several gatherings on 8" before getting the bad tires replaced looked a little funky but it made it easier for a fat man to get in and out of. :rofl2:
Here is some previous discussion on the topic......
http://www.mikenchell.com/forums/viewtopic.php?p=2244#2244
Postby bobhenry » Wed Oct 13, 2010 11:35 am
You want to see a drunken Duro tire here are a couple shots...
Got us home (our very 1st outing and no spare )
but it was rubbing on the frame and the outside wall of the trailer (wheels under).
I love the smell of burning rubber but I would rather it be at the drag strip not eminating from under my trailer.
Postby TPMcGinty » Wed Oct 13, 2010 4:44 pm
Have you tried looking at Northern Tools? They have a 5x8 trailer they have on sale every once in a while for under $300. It's the one I used. Works great!
Tim
TPMcGinty
Images: 146
