2bits wrote:There is this stuff called ironically: "Bartop". It is that stuff you see on countertops at bars and stuff. That is a super high traffic area and goes on thick. I lost all my dang bookmarks when I switched computers and I can't find the place again, but basically it is the stuff you put on countertops!
john wrote:Seeing as how the OP OK'ed slightly of topic posts, I thought I suggest another counter top choice.
On both of my builds I used prefinished hardwood flooring. Being that it is intended for floor use it is fairly durable.
doug hodder wrote:Not sheet metal, but I've done stainless in 2. Only had it sheared and 1 90 degree bend on them, rests on a ply sub base. I did a scuff treatment with a DA sander on it...Doug
Dusty82 wrote:Just a suggestion: If you can afford the extra weight, you can often pick up mis-cut solid surface countertops at mid to high end countertop shops for a reasonable price.
Jst83 wrote::lol: This thread has taken a whole nuther turn, not that I mind lots of good ideas going on here for galley counter tops
