Air Conditioner
Air Conditioner
Postby hoofhearted » Thu Oct 14, 2010 10:25 am
I don't know if this has been discussed already but has anyone mounted a small 5,000 BTU a/c unit in the front of their tear? I''m planning to build a BenRoy and was thinking about mounting the a/c in the flat part in the front. I'm more concerned about air circulation in and out of the unit more than anything.Thanks.
hoofhearted
Postby GPW » Thu Oct 14, 2010 5:40 pm
Hoof , sounds fine if your structure is made to support it ... But you may want to make a removable hard cover for it for towing and storage ..
Postby planovet » Thu Oct 14, 2010 6:11 pm
It's been done several times. You have to make sure and build an enclosure for the AC or water will get in if you are driving in the rain.
A couple of examples I found real quick:
ImageMark (& Cindi)
planovet
The Cat Man
Postby mikeschn » Thu Oct 14, 2010 6:53 pm
Gary has one on the Winter Warrior that worked well.
The one I stuck in the wall of my Winter Warrior leaked like a sieve when I first installed it. It took a lot of weather stripping to keep it from leaking. But still, I think Gary's design is better. Gary, got a pic of your design handy?
Here's mine...
Postby bdosborn » Thu Oct 14, 2010 9:40 pm
Now you see it:
Now you don't:
:lol:
Images: 806
Postby Shadow Catcher » Fri Oct 15, 2010 7:47 am
The other alternative is to not have the AC attached permanently. I have had a 5000 BTU unit adapted so that it takes 4 inch ducts, and these will be run into deck plates in the side of the camper.
A/C
Postby hoofhearted » Fri Oct 15, 2010 10:24 am
All great ideas guys. Thanks.
hoofhearted
Postby b.bodemer » Fri Oct 15, 2010 11:17 am
I really like Bruce's idea. Add a slideout and a baggage door and you are good to go.
I used the same idea for my TTT installing a bigger baggage door on the side and sliding the ac out when needed.
http://barbsserroscottymakeover.shutter ... mpergetsac
On my td I went with an insert to the side door. Since I had two doors I didn't mind for the few times ac was needed that I gave up the use of one of the doors.
There's no wrong way to ac...............as long as it keeps you cooled off!
Barb
b.bodemer
Images: 328
Postby Lou Park » Fri Oct 15, 2010 7:37 pm
I guess that would be a yes
Lou Park
Images: 5
Postby chorizon » Fri Oct 15, 2010 8:30 pm
That's exactly how I planned mine...
chorizon
Images: 94
Postby RAYVILLIAN » Sat Oct 16, 2010 7:54 am
Here is the Ac set up on the WW.
Since the bed is raised I put a vent inside to shoot the cool air up and along the roof where is returns back under the bed.
Gary
111961Image
RAYVILLIAN
Images: 109
Postby cracker39 » Sun Oct 17, 2010 2:01 pm
Building a TTT with galley in front, and planning another, ditto, I put the AC in the rear where water wasn't blown into it when driving so it didn't need a cover.
It was positioned where it might blow on the heads of anyone sitting on the couch, so I bought a Haier 5K BTU unit that has the air outlets that blow UP and OUT. You might consider that factor in a TD. Having one blow air up toward the ceiling rather than directly over you while sleeping in it might be preferable.
The PT will be too low to mount on in the rear, so I'm putting a mount in the side with an outside cover. The AC will sit on the floor for travel and put in the mount for use, pushing the cover up as it slides in (after unlocking the cover that is).
Dale
cracker39
Images: 233
Postby tuber » Tue Oct 19, 2010 8:53 pm
Does anyone have manyfacturers for small A/C's? I'd be interested in 12V and 120V units. I still haven't decided which power to use. Probably come down to reliability, and cost. I did see the name Haier mentioned.
There are only two types of water vessels---Submarines and targets
tuber
Postby Shadow Catcher » Wed Oct 20, 2010 9:03 am
Florida+12 AC, not a chance with out a huge battery bank and way to recharge it. The thread above mentions a 12 V swamp cooler, but the individual is in Wyoming where it does tend to stay pretty dry. Virtually/probably all of the small A/C units come out of China and they tend to be pretty much same same! All four of our small A/C units, three for the house, and one for the tear, are Frigidaire and you guessed it made in China. We had a bad experience with a Haier remote room AC that unfortunately did not have manual controls and the controller failed, we returned the unit. A good bit depends upon what you want in the way of features, digital and remotes add to the cost of a basically very simple unit. We have been very happy with our basic 5000 BTU Frigidaire unit and I picked it up off season at Lowe's for something like $50.
Postby GPW » Wed Oct 20, 2010 10:15 am
QUOTE: "I picked it up off season at Lowe's for something like $50." Now we're talking ...
8) :thumbsup:
