Wiring A Tear
Anything electric, AC or DC
Wiring A Tear
Postby Classic Finn » Sat Oct 23, 2010 3:50 am
Has anyone here routed out a groove on the outside of the walls to run elctrical wiring through before skinning?
Classic Finn
Midnight Sun Voyager
Images: 146
Postby PaulC » Sat Oct 23, 2010 4:41 am
Me, Me...............................pick me :lol:
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Postby Classic Finn » Sat Oct 23, 2010 5:07 am
PaulC wrote:Me, Me...............................pick me :lol:
Cheers
Paul :thumbsup:
Well Gday Mate.. Ok your picked :lol: How are you Paul? Long time no see. :D
The reason I ask is that Id like to do so on the Kits except I dont know exactly where to begin to do so.. :oops: :D
Paul or anyone, if you or anyone have pics Id sure love to see them to get some ideas. :yes: :designing:
For some reason or another Bubbas Garage, Lindner did this .. just cant remember for certain. :thinking:
Classic Finn
Images: 146
Postby PaulC » Sat Oct 23, 2010 5:13 am
Bingo..........................Just like magic
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Postby Classic Finn » Sat Oct 23, 2010 5:15 am
PaulC wrote:Image
Cheers
Paul :thumbsup:
Now that is magic :lol: Thank You Paul :thumbsup: What thickness is your ply 20mm? Or is it thinner?
Classic Finn
Images: 146
Postby PaulC » Sat Oct 23, 2010 5:29 am
17mm Heikki
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Postby Classic Finn » Sat Oct 23, 2010 5:31 am
PaulC wrote:17mm Heikki
Cheers
Paul :thumbsup:
Aha so I thought it looked thinner than 20mm Ive been thinking along the lines of 17mm or thinner but again have to be careful with the router so not to go too deep if ya know what I mean :lol: ;) Ive got a freind of mine here that says to go with the sandwich build since it will be lighter and he could do the wiring areas at the same time. Ive got alufibre ordered as well instead of the aluminum or Ive also got 0.06mm stainless here which is real nice for the outer roof and or sides. ;) But I need to get the elctrical groove done before that.. :thumbsup:
Ive got some nice looking classic lighting for the Kit also which will look quite impressive. I,ll take a couple of pics for you shortly. :pictures:
Classic Finn
Images: 146
Postby PaulC » Sat Oct 23, 2010 5:34 am
Heikki, That pic is part of my No5 build. The wiring on this one is actually on the inside. The glue is for the veneer that I place over it. Same principle for the outside but you use aluminium.
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Postby Classic Finn » Sat Oct 23, 2010 5:50 am
PaulC wrote:Heikki, That pic is part of my No5 build. The wiring on this one is actually on the inside. The glue is for the veneer that I place over it. Same principle for the outside but you use aluminium.
Cheers
Paul :thumbsup:
Youve been a busy man Paul at number 5 :oops: :oops: Thank you for the info ;)
Classic Finn
Images: 146
Postby PaulC » Sun Oct 24, 2010 3:16 am
slowcowboy wrote:I bury my wires on the inside in 2 inches of foam extruded insultaion. I have like 3 inch thick walls on my teardrop. Slowcowboy. you live in wyoming heat is more of use to you on a teardrop in the summer than airconsdioning or a just plywood for walls on a teardrop.
The R rating (insulating efficiency) of 17mm plywood is better than, or at least equal to, your ridiculously thick walls, Slowcowboy.
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Postby bobhenry » Sun Oct 24, 2010 7:56 am
HUH ?
17 mm [5/8] plywood has an R value of .78
a sandwiched wall with 1/2 ply each side and 2" of foam is 8.14 according to this info.
http://www.sizes.com/units/rvalue.htm
Ridiculious is in the mind of someone who may not fully understand -17 degrees.
Our winter/summer barn has OVER 2" of insulation in our riduclious walls and somewhere
in that foam we found a path for the 12-3 romax I used in the build.
These 2 1/4 cavities were filled with 3/4 blue foam
Floor has 3/4" of foam under a finished floor and here is a shot of the side walls insulated and ready for paneling.
Postby Larry C » Sun Oct 24, 2010 8:06 am
PaulC wrote:Image
Cheers
Paul :thumbsup:
Hey Paul,
What brand of mustard is that? :R
"If its worth doing it's worth doing Light"
http://www.tnttt.com/viewtopic.php?f=50&t=35852
Larry C
Images: 78
Postby PaulC » Sun Oct 24, 2010 11:29 pm
bobhenry wrote:HUH ?
I knew someone would bite :lol: Thanks for clearing that up for me. I may need to go back to school, Huh ;)
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Return to Electrical Secrets
