Sorry , I keep going back to what they use on trains ... We've done a LOT of train travel (I don't fly) ... and just got used to their fold up bunk/sofa system... Which is what I appreciate so much about your setup ...
GPW wrote:Don , EMT , electrical conduit , available at most hardware stores.. It's inexpensive , comes in many sizes, and strong ... I've made chopper bicycles from it ... It seemed like the simplest idea for a pivoting bunk using the E-track ...![]()
d30gaijin wrote:Might you have any thoughts on where I can buy some cabinetry, like a simple pre-made overhead double cabinet I can attach to the inside wall of the CT? Thoughts on a fold down table design?
Camper wrote: Hey Don
Sorry i did not see your reply and question.We have been very busy with our move over off Maple Grove Rd.
The material i used for my roof and sides of my trailer is a recycled material 4x8 sheets i actualy found at Home Depot.It is like a vinyl material that is totaly from recycled material and is only about $19 a sheet.All trim i used i also plastic and or vinyl from Home Depot and or Lowes as i work at Lowes and can use my discount on everything.Lowes did not have that material so i was forced to go to H.D.
With the move i had to stop working for a while on the trailer but hope to be able to finnish the final details soon. Oh also to put the icing on the cake the engine went out in my truck so i don't even have a way th pull the trailer til the new engine gets put in,the engine had internal failure at 169 k miles
Will post a picture as soon as i can .You can see the material at HD it is back where the fiberglass sheets are at the back wall of the store on Milwaukee.
Derrick
GPW wrote:Don, That's Great !!! Looks like you have your needs all sorted out ...Nothing like a little camping to let you know what you don't need eh ....
I think we all plan out trailers like we were going to Live in them ... then after camping , unload half of it as "not needed" ... making room for the stuff you Do need ...
GPW wrote:There is a big advantage to Stealth camping !!!! There are so many contractors running around this town with CTs , one more wouldn't be noticed at all ...![]()
For real Stealth , we could get some magnetic signs for the pickup tow vehicle ... something like "Joe's Hazardous Waste Removal "... with (removable) HAZMAT and Radiation Warning stickers on the CT .... That would keep em' away for sure...
bobhenry wrote:GPW wrote:There is a big advantage to Stealth camping !!!! There are so many contractors running around this town with CTs , one more wouldn't be noticed at all ...![]()
OH OH OH >>>>> Add those ground effect light under the belly in an erie lime green.![]()
Then if you could just make them pulsate :thinking:
d30gaijin wrote:GPW wrote:We were discussing what kind of contractor signs would draw the least attention (don't want some dork trying to break in thinking he'll find thousands of dollars worth of tools inside) but came to no conclusions.
