Help with Torsion Axle
Postby dhazard » Sat Jan 14, 2006 11:09 pm
I am going to order my axle this week :D , any suggestions on the bests bang for the buck on a 2000lb torsion axle with mounts for breaks.
I would also appreciate any input on the specks that the company will require for dimensions.
The trailer frame will be 62” wide.
The rim / tires have a 5.5” backspace.
What would be the best hub to hub distance?
The starting angle?
Thanks to all, Dan
Many miles and many tears. Times were hard but now they're changing.
You should know that I'm not afraid.
dhazard
Images: 122
Postby asianflava » Sun Jan 15, 2006 12:52 am
I ordered mine from a Dexter dealer, I got this from their website and wrote it down.
The info you will need will be:
1 Gross Weight - I kinda guessed, on this. I hope to have it less than 1000 but I wasn't shure what it would come out to so I got a 2K axle.
2 Number of axles - This one is a no brainer
3 Brakes - I do not plan on using or needing brakes
4 Axle length - This was tricky, I took the wheel (with tire mounted) and put it flat on the ground. Then I measured from the floor to the bolt flange to get the true measurement then add an inch or two for the sidewall/tire clearance. Double that total and add it to the total width of your tear body.
5 Bolt Pattern - I used a 5X4.5 you are actually limited on this as the heavier axles aren't available with the smaller bolt circle.
6 Outside frame dimension - This is easy, just measure where the frame will go. My frame went inside a "Skirt" but most people just use the outside body dimension.
7 Torsion arm start angle - I guessed on this one too. I figured that 45 down would be too much and 0 may not be enough. I split the difference and got a 22.5 down angle. It is a little high but it tows flat when hooked up to my wife's SUV.
Oh there are some other things that they will ask.
Mounting type - Weld on or bolt on
You also have the option of the 6.5in hub flange. I think this is the default if you get the 5X4.5 bolt pattern though.
Hope this helps
asianflava
Postby madjack » Sun Jan 15, 2006 1:38 am
...62" frame rails, + tire offset x 2 = 11" =73 + clearance to frame...another 2" for 75"...is the body coming down over the frame...is so add that number(bothsides) to the 75 and that is your HUB to HUB measurement...we have the Flexiride and with 0% start angle and 205-70-15 tires we have 13" of ground clearance...so you have frame rails at 62'"s and a H2H of 75/76.5 and a start angle of choice
madjack 8)
Postby bdosborn » Sun Jan 15, 2006 2:36 am
Here's a site that sells axles and has diagrams on how to measure for your axle.
http://www.bageco.com/traileraxles.htm
Images: 806
Postby angib » Sun Jan 15, 2006 7:49 am
Here is Dexter's Axle Measurement Guide which defines each of the measurments that asianflava mentioned.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby dhazard » Sun Jan 15, 2006 2:44 pm
Thanks to all for the input. :thumbsup:
The trailer will only have the siding on the outside of the frame so the 62” + 11” (offset x2) + 2”or 3” (frame clearance) for 76 H2H was what I was thinking. Thanks for the confirmation Madjack, and the 0 start angle with 13” of clearance should work for a good height behind my Camaro.
Now any suggestions on the bests bang for the buck on a 2000lb torsion axle with mounts for breaks part of the post. :worship:
Dan
dhazard
Images: 122
Postby bdosborn » Sun Jan 15, 2006 3:32 pm
I haven't been able to find 2000# with brakes, it seems like you have to go with a #3500# to get them or special order an axle. Let me know if you find one!
Images: 806
Postby dhazard » Sun Jan 15, 2006 3:49 pm
dhazard
Images: 122
Postby Nitetimes » Sun Jan 15, 2006 3:54 pm
I know you can get the 2k torflex from Redneck and Lucky B with brake flanges but I can't say which others have them. I would think you can order them with the flanges from most places.
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby Gaston » Sun Jan 15, 2006 4:20 pm
I bought my 2000lb torsion axle from centurywheel/quality axle store in Oregon. sized to my specs for $145.00 their web site is www.qtrailer.com
I am picking mine up at their store so I dont know what shipping would be. (the shipping for an axle shipped fron Texas was going to cost me $135.00!)
The difficult we do now... the impossible takes a little longer
Gaston
Images: 98
Postby madjack » Sun Jan 15, 2006 10:36 pm
Flexiride can be had with brakes as can Torkflex, thru redneck trailers inna 2000# axle
madjack 8)
p.s. Gaston, that link didn't work...coulja check it again
