S. Heisley wrote:I've walked on Styrofoam and it gradually squishes down (unless there is plywood on top of it). You might be better off with an inch or so thickness of a real carpet foam base. That used to cost about 50 cents a linear foot, but it probably costs more now as I haven't bought it in a while. Anything between you and metal will help, though.
This one is just a thought; don't know for certain if it would work:
If your trailer is not going to be moved all winter, why not put up a temporary plywood (or Styrofoam) skirt around its base? Not only would that keep the wind from blowing through underneath but also, it would probably retain a little more of the escaping heat under the floor so that the metal stayed warmer; thus, the cabin might stay warmer too.
d30gaijin wrote:South Penn,
Find a more efficient electrical heater! They are out there.
To heat a 6x10 foot CT doesn't take much. Shop the thrift stores, that's what I did, and found a dandy little 1000 Watt heater with a built in fan that heats our 6x10 CT with no problem. The fan is the key in that it moves the heated air around. I have no insulation in the floor of my CT but it stays warm inside with the Honda EU2000i running at half mast to power the heater i.e., it will go all night and keep the CT warm on a half tank of gas, and a tank full in the EU2000i isn't even one gallon (a tank full is something like .9 gallon so I can heat our 6x10 CT for about .4 gallon on a cold night and fully charge the battery ta boot). Or! Buy a $7 electric fan and face it towards your current heater from a distance to move the air around. The fan moving the air is critical, other wise the heat just goes up and out the top of the CT.
I presume your CT is insulated? If not, then insulate it. It makes a difference. At least insulate the roof as that is where the heat escapes.
Don
southpennrailroad wrote:I find that using the stove
to heat quickly and the fan to distribute it through the trailer. Otherwise it is cold on the floor until I turn the fan on the stove.
