GPW wrote:Apologies !!! Not YOU Fox !!!!![]()
2bits wrote:To answer the initial question, I think people tend to over engineer the frame, and the walls the most. I think I did well in this area. 3/4" plywood walls, but I am most proud of my frame.
(Obligatory photo)
jimqpublic wrote:2bits wrote:To answer the initial question, I think people tend to over engineer the frame, and the walls the most. I think I did well in this area. 3/4" plywood walls, but I am most proud of my frame.
Quite beautiful and simple. I like the uncut diagonals and extra member in front.
Just one question on the design: Once the trailer floor is bolted down, does the central crossbeam really do anything? It looks redundant with the torsion axle firmly bolted in place.
And a second question related to use- what is the hitch ball height and have you experienced problems with it being so low?
Judeyramone wrote: Since my TV is an F-250, capable of towing 825,000lbs... extra weight on the trailer frame is a reasonable compromise when planning my project.
Judeyramone wrote:No, it was an exaggeration... I think I'm good for 7,800lbs towing/600lbs tongue weight. Whatever my actual towing limit, a teardrop isn't going to be anywhere near it & I have a little room to overbuild... to the tune of several hundred (or even several thousand) lbs.
One advantage of a small trailer - gas mileage. Truck burns enough gas on its own. A light trailer will affect an already enormous fuel bill much less so than a big, heavy 5th-wheel.
