Postby GPW » Tue Nov 16, 2010 11:39 am
Aggie, Thanks Tom !!! Great link !!! :thumbsup:
Postby eaglesdare » Tue Nov 16, 2010 11:43 am
yes great link. i was just checking it out.
Louella
May the foam be with you.
eaglesdare
Postby GPW » Tue Nov 16, 2010 12:54 pm
... and that appeared to be 1" foam ... laminated in a few spots ...I'll bet it's LIGHT !!!
I remember a while back Glassice built TDs out of foam and fiberglass... :thinking:
Postby aggie79 » Tue Nov 16, 2010 1:14 pm
GPW wrote:... and that appeared to be 1" foam ... laminated in a few spots ...I'll bet it's LIGHT !!!
GPW,
I've seen it up close and in person. I want to say Dave used 3/4" foam but can't say for sure. I'm thinking 3/4" since that would work easier for the 1x lumber and 3/4" plywood used for some of the hardpoints.
Dave built most of the components separately, and then he and Cindy had a barn-raising party to assemble the teardrop. I wanted to go, but had a conflict that weekend.
It really is a very nice teardrop.
Postby GPW » Tue Nov 16, 2010 5:31 pm
I surely would like to have seen that ... :thumbsup:
Postby eaglesdare » Wed Nov 17, 2010 7:55 am
another question: i know you say thicker is better or stronger. so which would be better: two pieces of 1" foam glued together, or one piece of 2" foam?
Louella
eaglesdare
Postby starleen2 » Wed Nov 17, 2010 8:19 am
eaglesdare wrote:another question: i know you say thicker is better or stronger. so which would be better: two pieces of 1" foam glued together, or one piece of 2" foam?
One piece foam Ia always better than two glued together - but if you have two pieces and NOT one then glue them together. All this to say - : if you have the choice - go with the one piece. Lot less hassle with the gluing
starleen2
5th Teardrop Club
Postby eaglesdare » Wed Nov 17, 2010 8:51 am
thank you. :D
Louella
eaglesdare
Postby GPW » Thu Nov 18, 2010 9:04 am
Eagle , done with that model yet ... :o If I have a little extra time , I have the materials ,and may try one myself ... Great way to visualize a Proof of concept ... Cheap! :D
We could , in a pinch , use corrugated cardboard for the model ... :roll: Sorta' simulates the thickness of the foam .. and is readily available from any cardboard box... Just a model eh ?
Postby eaglesdare » Thu Nov 18, 2010 10:58 am
no i haven't done my model yet. had a tooth extraction yesterday afternoon. not feeling great today. hopefully this weekend i can get out and get some stuff. i want to take a ride up to michaels craft store.
Louella
eaglesdare
Postby GPW » Thu Nov 18, 2010 12:06 pm
OUCH !!! No FUN !!! Best rest up till you feel better... !!!
Fun going to Michaels !!! ... more than I'd ever need , or could afford ... :lol:
Postby GPW » Sat Nov 20, 2010 8:45 am
Got a little time this weekend ... I think ? Haven't consulted the wife yet ... :oops: But starting on a small Proof of Concept model of a Foam trailer.. Going to try and use as authentic materials as possible . Plywood floor , 1/2" foam walls , 1/4" foam for roof and insides (?) , and an old sheet for covering ... T2 and epoxy for glue ...just as with a big trailer ... No attempt at a scale model , just something to see how easy this would actually be ... I'll take some pics as I go ... sorta' like a mini build thread .... :lol: Stay Tuned !!!
Postby eaglesdare » Sat Nov 20, 2010 10:50 am
i am looking forward to it! however, can you not use epoxy? i don't want to use that for a real build.
(still not feeling well with this ex tooth spot, so i am staying doped up and not venturing out. must be gettin old, as i am not healing as fast as i used to. :(
but i will be checking in often to see what you have done.
i started a box like experiment, just like the one posted in this thread, but my cat took it over. :lol:
what exactly would you being using epoxy for? can you substitute?
Louella
eaglesdare
Postby GPW » Sat Nov 20, 2010 11:19 am
I'd only be using 5 min. epoxy for the foam to foam joins ... could use gorilla glue , but it would take too long to dry for me ... either should be fine on a bigger build ...
Luckily my Cat is inside , far away from my projects ... :lol:
Postby GPW » Sat Nov 20, 2010 1:17 pm
OK, all done with the construction phase ... here's a little teaser... the rest of the build pics are in my Album ... Sorry , didn't want to clog up the pages here ... :roll:
Next is the covering ... :thumbsup:
Users browsing this forum: jgmahoney and 12 guests
