jeep_bluetj wrote:Clean to bare metal.
Ring terminal, self tapping screw.
Prime and paint over top of it all when it's assembled.
Same idea as the dielectric, but lasts longer.
Yup, thats how I did it but I used dielectric grease.
wlooper89 wrote:Miriam C. wrote:
RV manufacturers do ground AC to the vehicle frame, and I believe it is in their wiring code to do it that way. DC negative can also be grounded to the trailer frame or not, either way is fine and does not interfere if both AC ground and DC negative are attached to the frame. Usually the vehicle frame is used as negative for the 12V running lights, probably to save wire.
Bill
Steve_Cox wrote:You don't need no stinkin ground wire to the frame.![]()
Dedicated ground wires always work better, most of the time 12V failures are due to a faulty ground.
