cuyeda wrote:Nice start! For the 5x9+1" what mods did you do to the frame, if any.
Ratkity wrote:Wonderful progress!!! How are you going to handle the heat from the back of the frig? I'm sure it would be a positive thing to have in the winter.
Hugs,
Ratkity
nevadatear wrote:I haven't seen a drip rail with that angle before, but lots of folks have made wood drip rails, including us. I, too ,would be a little concerned about the exposed edge. It would work if you used some fiberglass and seriously epoxied it. But you might want to consider something other than ply. A length of 1 x pine should be pretty cheap and you don't have the edge issue.
Plus, to keep the water from just rolling forward, Randy cut an notch on"L" cut out on the top-back to make a "track" for the water to run to the sides, like regular metal drip rail. That would be hard to do in ply and get it protected into the layers.
But for any wood you still need to make sure it is well protected. CPES or epoxy, before attachment. And attach with a marine sealant. It will of course get wet. Ours seems to be working out fine for us.
Oh, and your build looks great!
Users browsing this forum: Bing [Bot] and 13 guests
