I just put a new style marker light on my fenders and consequently have a couple of screw holes from the previous mounts in each fender. Can anyone tell me an easy way to plug them?
Appreciate it,
Scott
madjack wrote:...put a screw innem...orra rivet...orra bolt/machine screw w/nut...preferably in stainless to avoid rust...I guess you could have 'em welded up as well...assumin' ya still got the Lil Guy w/AL fenders.............
toypusher wrote:Like Jack said, if they are steel, just a quick little spot weld on each then a little grinding and paint. Also could use some bodo on them.
Trackstriper wrote:Following on toypusher's idea, you might be able to put a little masking tape on the backside of the holes as a backer then fill the holes with a little standard cure-time JB Weld. You can mix it accurately in fairly small quantities and it sets to a gray color. Trim flush with a utility knife blade. I don't think the five-minute cure JB Weld does as good a job, generally, although it's great for fast repairs.
Zollinger wrote:Trackstriper wrote:Following on toypusher's idea, you might be able to put a little masking tape on the backside of the holes as a backer then fill the holes with a little standard cure-time JB Weld. You can mix it accurately in fairly small quantities and it sets to a gray color. Trim flush with a utility knife blade. I don't think the five-minute cure JB Weld does as good a job, generally, although it's great for fast repairs.
That's what we did on our Vagabond. Someone at one time attatched a roof over her and screwed into the aluminum. We made a aluminum patch for the inside and spread JB Weld on the patch and held in place with painters tape until it cured. We should be able to bondo over it on the outside when it comes time for paint.
