1947 Kit Rebuild Update as of 23 February 2011
Postby Classic Finn » Tue Nov 02, 2010 2:12 pm
I have a question. Has anyone here installed a nose wheel onto the Kit? Im thinking if I should install one. If any of you have could you kindly show a pic of it and how its been installed?
Classic Finn
Midnight Sun Voyager
Images: 146
Postby Gage » Tue Nov 02, 2010 3:17 pm
How is this?
Image Image Image
Gage
Images: 28
Postby Classic Finn » Tue Nov 02, 2010 4:19 pm
Gage wrote:How is this?
Yes my friend Gage dat b it. How is that installed? I see that pipe coming down from the front of the yours. & I thought maybe that was the place for it but maybe Im wrong :thinking: ;)
Classic Finn
Images: 146
Postby Classic Finn » Tue Nov 02, 2010 5:01 pm
This is the wheel I found available here.
Good up to 150 kilo.
and for choice 2 this.
I kind of like the air filled better though.
Classic Finn
Images: 146
Postby doug hodder » Sat Nov 06, 2010 1:37 pm
Heikki...that little stub that is left on Gages was for a caster. It didn't raise or lower, and the original casters were made of steel, at least mine was. You just pinned it on for moving the trailer. Doug
Postby Classic Finn » Sat Nov 06, 2010 1:49 pm
doug hodder wrote:Heikki...that little stub that is left on Gages was for a caster. It didn't raise or lower, and the original casters were made of steel, at least mine was. You just pinned it on for moving the trailer. Doug
Thank You Doug. Thats what we kind of thought. But wasnt sure. Great to hear from you. Sure missed you. :yes: :shake hands:
Classic Finn
Images: 146
Postby Classic Finn » Fri Nov 12, 2010 3:48 pm
Well finally we got the 1st Kit frame back. It sure looks sweet now compared to the ol rust bucket it was. :lol:
Waiting for the new tires to be set onto the original rims it came with.
I,ll get some photos for you in a bit but need to wait till it stops raining. Meanwhile weve built the sandwiched floor for it instead of just plain ply. ;)
Here,s the way we built it with stainless on the bottom outer core. :thumbsup:
Classic Finn
Images: 146
Postby Classic Finn » Fri Nov 12, 2010 4:11 pm
Here,s a couple of quick pics for you. These photos dont do this justice because its raining and its really dark at this time of year. Its much nicer looking than what these pics show. I,ll get some better shots in day light.
The frame was bead blasted galvanized and powdercoated in our small southern neighboring country of Estonia. Why you may wonder?. Reason. Its 3/4,s less the price there as it would of cost here. The work is also the same quality there as it would of been in our country.
Also these heavy chains will still need to come off since we dont use them here but instead a safety wire. ;)
We took the spare tire holder frame off due to it causing too much weight.
New tires will be on next week.
Notice our style of coupling on the towbar. :)
Classic Finn
Images: 146
Postby High Desert » Sat Nov 13, 2010 12:44 am
what are you trying to do Heikki, make it brand new again? :lol:
Looking great pardner, and I can tell you're having fun with it too. That's as it should be 8)
Shaun
High Desert
Images: 27
Postby Classic Finn » Sat Nov 13, 2010 1:57 am
High Desert wrote:what are you trying to do Heikki, make it brand new again? :lol:
Hello Shaun and greetings from our entire family to you all.
:lol: Might as well since it came to us so far a distance from Cali-for-nia. :) Thank You. Yes Im njoying this a lot.. ;)
Classic Finn
Images: 146
Postby Classic Finn » Sun Nov 28, 2010 5:09 pm
I have a question. How can I insulate this Kit with minimal space loss?
I see when I tore it down the ribs crosswise were open in the ceiling front to back cabinets.. :thinking:
Classic Finn
Images: 146
Postby Ageless » Sun Nov 28, 2010 6:22 pm
Foam sheets come in 1/2" thickness. By removing the plastic film from one side it becomes flexible.
Ageless
Postby Gage » Sun Nov 28, 2010 6:59 pm
Well Heikki, I used 3/4" foam on the roof. Didn't worry about the sides. But then again the weather here is a little different than there. :thinking:
Image Image Image
Gage
Images: 28
Postby doug hodder » Sun Nov 28, 2010 10:21 pm
Heikki....think about your camping conditions. Is it going to be used for winter camping? With a body or 2 in it overnight, it will be fine...it's the getting outdoors temps. in the morning that is going to be your problem....get a fire going right away! If it isn't planned to do the really cold camping...just do up the ceiling like Gage mentioned (I'd do that anyway) and go for the solid walls like it was originally constructed.
With decent bedding I've camped down to the lower 20's F with ply construction walls no heat and been fine. If you want lower than that...I'd plan on going with some wall insulation, which will involve either cutting down on the inside space, or cutting into the clearance on the tires, your choice. It kinda comes down to how much room you have to work with side to side and how low do you want to go. Just my opinion.
PS...dogs are great heaters! Doug
Postby Classic Finn » Mon Nov 29, 2010 11:35 am
Gage wrote:Well Heikki, I used 3/4" foam on the roof. Didn't worry about the sides. But then again the weather here is a little different than there. :thinking:
Thank You Gage, didnt realize you insulated yours, must be gettn old. :lol: The floor I have insulated already. The sides I reckon can be left alone but the front to back ceiling I shall do. :thumbsup:
Thank you my friend. All our best to you and Tanya.
Classic Finn
Images: 146
