Hello,
İt looks good and i like the name and logo of Green Lanten,
S. Heisley wrote:Nice! Is this one gonna be the final keeper?
starleen2 wrote:Well folks had a wee bit of time to work on the green lantern. As mentioned before the floor is done.
Now time to attach the walls
Muscling back wall into place – getting everything lined up before the glue sets. So far so good.
Everything in place – I decided to have some wallpaper boarder printed up to match the Coleman fabric – you can see it in on the back wall
Here is a close up – it’s only a test pattern to check for repeatability and size.
Even got some insulation on the walls
Other side – still have to cut out the window. The front cutouts were done with a router and trim Bit – Now that how to do it! – Just zip around the edges and you’re done. How did I ever get by without one? Now you can see the lamination strips on the side (three rows)
Finally Done for the day
The strips are just temporary until I get ready to close everything up. Right now I still have some big pieces that need to be installed. The blue tape is th layout for cabinets and Bed/seating spaces
Classic Finn wrote:Question for you. Did you use screws or nails with glue of sorts to mount the sidewalls onto the floor?
Dusty82 wrote:. . . With so many people using SketchUp to design their tears and TTTs, I wish there was a forum for sharing the SKP files for our various designs. I know I'd love to get my hands on the SKP files of a few of the designs I've seen here.
starleen2 wrote:Dusty82 wrote:. . . With so many people using SketchUp to design their tears and TTTs, I wish there was a forum for sharing the SKP files for our various designs. I know I'd love to get my hands on the SKP files of a few of the designs I've seen here.
there are a few of us who are trying to get a repository going for sketch Up designs. I do plan on posting the design in the design library once it is finally done. I like to use SketchUp to model with because it gives me accurate dimensions so i can plan out everything before I start to build - the make fine adjustments as I go. If you are interested it should be available in the 3d warehouse
