absolutsnwbrdr wrote:Sounds like a grounding issue between the fender and the trailer. Test it out by running a ground wire directly from the light to a grounding point directly on the trailer.
absolutsnwbrdr wrote:If thats the problem, it'll probably be easier to just run a ground wire directly to the frame.
I had horrible grounding issues with my POS bolt-together HF frame![]()
Ended up running a dedicated ground wire for the whole trailer.
Steve_Cox wrote:I gave up long ago trying to keep a good ground through a trailer frame, fenders etc... The last 20 years or so, I've run ground wires to all trailer running/turn/brake lights. A little extra wire can simplify your life. Attachment of a ground wire to a side marker can be as simple as a ring terminal under the fixtures attaching bolt.
Oasis Maker wrote:I'm a little baffled though at everyone having problems with a ground even at the trailer frame? Wouldn't that be a slam dunk to just drill a little hole in that thick metal, bolt on and wallah??
Scott
madjack wrote:Oasis Maker wrote:I'm a little baffled though at everyone having problems with a ground even at the trailer frame? Wouldn't that be a slam dunk to just drill a little hole in that thick metal, bolt on and wallah??
Scott
Scott, you would think BUT, there is also the connection back to the tow and the additional problem of corrosion between two different types of metal and???????...well anyway, it presents some not unsolvable problems but a direct ground connection from the harness ground to a grounding block to all other grounds will usually eliminate these problems and give a common point to check if further problems occur........
Larwyn wrote:I think it is probably those of us who have spent lots of time trouble shooting trailer lights that are most likely to simply run a dedicated ground wire to all of the lights. Bad grounds are almost always the cause of trailer light problems .
