My trailer has a sheet of aluminum for the roof, which I just cut to size. My question deals with the edging that will be running the length of the trailer on each side.
What should I use for sealant in between the edging and the aluminum roof?
A friend of mine used butyl tape; however, his edging seems shaped a bit differently than mine. It seemed to have a bit of concave space that the tape could fit into. My edging is totally flat where it meets the roof -- I'm wondering if the lack of space for the butyl tape would raise it off the roof a bit. Please correct me if this is not an issue -- I have no experience with butyl tape.
I also considered just using a construction adhesive, like PL, to seal and also help hold the edging to the roof. Would that work?
What is typically done?
