Bitter Cold Continues - Finland - Photo Greeting
Postby Classic Finn » Sat Jan 21, 2006 6:24 am
Greetings from the Ice Box..... It is coooooold. Cold From Siberia reaching us.. :shock:
Presently at -22 celcius at 13.20 Finnish Time
ImageMore Steam More Steam... :lol:
Classic Finn
Severe frosts immobilise cars and freeze pipes across Finland
The first really sharp frosts of this winter immobilised diesel cars and froze pipes in various parts of Finland on Wednesday. The record for this winter of minus 37.7°C was reported in the Naruska area of the municipality of Salla in Lapland.
The thermoregulation equipment of lorries delivering food had a hard time, for instance in Southern Karelia.
In Lahti, a trotting-race meeting was cancelled, and the local water supplier Lahden Vesi had to suspend work at a couple of water system sites lest old pipes be frozen.
Because of the hard frosts and icy winds, work has been stopped also at some northern construction sites.
Strong frosts are expected to prevail in most parts of the country at least until next week. Moreover, if the weather suddenly abated, the risk of the freezing of pipes would increase.
"Indeed, the next few days will be remarkably cold. In contrast to last year, even a quite long cold spell may be ahead", predicts meteorologist Mikko Jäntti of the Finnish Meteorological Institute.
"The weather will be distinctly colder than average, even though the frosts are not likely to reach any record levels."
The reason for the current weather is the strong high pressure centre in Siberia which has also extended to Finland.
Such anticyclones often tend to hang back for a long time. Hence a low pressure area approaching Finland from the west will probably touch only the western part of the country, weakening the frosts in those areas.
According to the weather forecasts, frosts of some -30 to -35°C can be anticipated in the northern and eastern parts of the country. In Southern Finland, temperatures below -20°C are likely, while a temperature of -15°C is predicted for the coastal areas.
By comparison, last January was several degrees warmer than average in Finland, and the severe frost period of the winter occurred in March. However, by then the strengthened sun was already warming up the country in the daytime.
During the current frost period hardly any snow is expected to fall in Finland, except for the western coastal areas.
Currently, there is little or no snow along the southern coast, while the snow cover in the southern and central parts of the country is some 20 to 30 cm. In Lapland, the snow cover varies from 30 to 60 cm.
The mild autumn slowed down the freezing of lakes and rivers. Because the waters were warmer than average until October, the current ice thicknesses are generally weaker than normally.
"Of course the current frosts increase ice thicknesses, but not as much as they would have done if the sharp frosts had arrived at the beginning of ice formation. Besides, the snow cover insulates the ice and prevents it from getting appreciably stronger", says hydrologist Johanna Korhonen of Finland's Environmental Administration.
According to Korhonen, ice thicknesses are generally below normal. The ice thicknesses of the lakes vary from 15 to 30 cm in Southern and Central Finland, and to 25 to 40 cm in Lapland. However, even in the same areas, ice conditions are changing considerably.
The bearing capacity of ice is measured on the basis of bright, transparent, flat and steely ice. A five-centimetre layer of steely ice can bear the weight of a single human being, while a snowmobile needs at least 15 cm of ice under its tracks. A passenger car requires 15 to 20 cm of steely ice under it.
The seas have frozen almost as fast as in the previous years, even though the sea water is currently still 1 to 2 degrees warmer than average.
The ice on the coast is 5 to 20 cm thick, and even thicker in some sheltered bays. Jouni Vainio of the Finnish Institute of Marine Research (FIMR) warns nevertheless that even though the ice cover will thicken further during the current frosts, it is not safe now to go out on the ice of the sea off Helsinki and Espoo, for example.
Previously in HS International Edition:
Mild January weather keeps lake and river ice dangerously thin (13.1.2005)
Classic Finn
Midnight Sun Voyager
Images: 146
Postby MeelisV » Sat Jan 21, 2006 7:03 am
you are not only one :snow
A woman has the last word in any argument.
Anything a man says after that is the beginning of a new argument.
MeelisV
Images: 105
Postby Classic Finn » Sat Jan 21, 2006 7:58 am
Hey Meelis.. Were glad your still with us coping with this Siberian Cold Express.....
More Steam to the Sauna Stove..... :snow :snow :dancing
Classic Finn
Images: 146
Postby Gary T » Sat Jan 21, 2006 9:26 am
-20 C here this morning. A little warmer than the other day -22'C
Just to let you know. I think Thunder Bay has the largest population of Finns outside of Finland.
Gary T.
The mind is like a parachute. It works much better when open.
Gary T
Images: 7
Postby Sonetpro » Sat Jan 21, 2006 9:56 am
Geeez I couldn't take it. :no: I hate the cold. I was born in Phoenix,AZ raised in New Orleans,LA and now live 50 miles north of Houston. Cold to me is any thing below 32F. 72 here yesterday and the same predicted for today and I love it. 8)
Sonetpro
Images: 107
Postby Juneaudave » Sat Jan 21, 2006 12:02 pm
At least the days are getting longer.... :)
Here's the Alaska report from todays Anchorage Daily News
A bone-chilling breath of air from Siberia and the Arctic blew across Western and Interior Alaska on Friday, grounding planes, closing schools and delaying the start of the Kuskokwim 300 sled dog race in Bethel.
The frigid air was sucked south by two low-pressure systems that threatened to converge in Prince William Sound tonight and wallop Southcentral Alaska with mounds of fresh snow, said National Weather Service spokesman Dave Vonderheide.
Weekend snow advisories and snow watches are in effect from the Kenai Peninsula to the Matanuska Valley, and Valdez could see as much as four feet of snow over the weekend.
"And that's in town," he said.
The airport at Chandalar Lake, tucked into a valley in the Brooks Range, shivered through the state's chilliest weather with an air temperature of 60 degrees below zero, he said.
Temperatures in the Interior were only slightly higher, with many villages dropping to 50 below and colder. That's as cold as the tops of the highest clouds, he said, "the really high clouds you see when you're flying in a jet."
It was 58 below in the center of Fort Yukon Friday, but it was warmer -- 52 below -- in Richard Carroll II's neighborhood.
"We're in the banana belt," he laughed
Juneaudave
Images: 380
COOOLD
Postby gman » Sat Jan 21, 2006 3:30 pm
Man trapped in toilet when lock freezes(1/20/06 - BERLIN, Germany) - When a 58-year-old motorist nipped into a German highway rest stop public toilet to answer the call of nature Friday morning, he had no idea how cruel nature could be.
Off highway A6 near the town of Lichtenau in Bavaria, which has been experiencing cold weather and snow over the past few days, the man found himself trapped in the toilet stall after the lock froze while he was inside.
Unable to pry the door open, the man finally was able to explain his predicament when someone occupied the stall next to him and get them to call police on a cell phone.
After about an hour in the chilly cell, police were able to get the door open and free the man, whom they described about "thoroughly frozen through, but in good general health."
Junk is something you've kept for years
And throw away three weeks before you need it.
gman
Postby Classic Finn » Sat Jan 21, 2006 4:42 pm
powderburn wrote:hhhmmmm
What is the conversion rate?
If I remember right,-40 degrees celsious is the same as -40 degrees farenheight?
That means that fins temps are at about -10 degrees F*.Thats not so bad unless the winds blowing too :thumbsup: The worst Ive seen is -65F* with windchills in the - triple didgets.I called in sick from work that day. :thumbsup:
Here,s a comparison of celcius to faherenheit:
Days are indeed getting longer, can hardly wait... :)
Class Finn
Classic Finn
Images: 146
Postby Classic Finn » Sat Jan 21, 2006 4:50 pm
powderburn wrote:WOW!!!
I was just complaining to the wife that I was going stir crazey because its too cold to work out side today.Its 36 degrees but the wind chill is in the 20s.
Odly enough...the cold doesnt bother me as bad as the wind.The wind just screws up every plan I try to make and ruins even the nicest days.
I hope you guys up there arent having the winds too.Im all to familiar with the cold and wouldnt wish it on anyone.
The Southern Part and the Coastline has winds picking up: Then its time toget into even warmer clothing.... And the windchill makes it much colder. In Russia many have already died from the cold temps...
Classic Finn
Classic Finn
Images: 146
Postby Classic Finn » Sat Jan 21, 2006 4:54 pm
Gary T wrote:-20 C here this morning. A little warmer than the other day -22'C
Greetings Thunder Bay... Yup Im familiar with your city.. Been there a few times... Had some Canadian Beer and including Finn Beer in a place
on Algoma Street... Visited the Sleeping Giant back a few years ago...
Definitely a lot of The Finns There...
Classic Finn
Classic Finn
Images: 146
Re: COOOLD
Postby Classic Finn » Sat Jan 21, 2006 4:56 pm
gman wrote:Man trapped in toilet when lock freezes(1/20/06 - BERLIN, Germany) - When a 58-year-old motorist nipped into a German highway rest stop public toilet to answer the call of nature Friday morning, he had no idea how cruel nature could be.
Yikes : Well lucky he didnt freeze his "Ol Arsh" onto the seat.... :shock:
Cant fool Mother Nature.....
Classic Finn
Classic Finn
Images: 146
Postby Gary T » Sat Jan 21, 2006 9:17 pm
Was this the place
Gary T.
Gary T
Images: 7
Postby Gary T » Sat Jan 21, 2006 9:22 pm
My wife has family in Vaasa and Maalax, and has traveled to Finland many times.
Are you close to that area of Finland?
Gary T.
Gary T
Images: 7
Postby PaulC » Sat Jan 21, 2006 9:53 pm
Currently+43C here in little old Adelaide. Nothing like going from one extreme to the other.
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Postby Micro469 » Sat Jan 21, 2006 11:05 pm
It's 2degrees celsius here in Toronto. no snow and unusually warm for this time of the year. Glad somebody else got it than me... can't stand the cold :lol:
John
Micro469
Images: 382
