arnereil wrote:I may take a model and mount it on a spring loaded arm and drive down the road at 30 mph and see what the spring tension is, then change the model with a different front (flat) and see that the spring tension is....
If the results are going to be at all accurate, you would have to tow the two trailer models behind a minivan model.
At least, I'm assuming you don't let the full-size trailer go down the road on its own.......
arnereil wrote:One thing that has always intrigued me is that a boat with a bulbous bow has less resistance than one with a knife sharp bow.....
Yeah, but it's not at all comparable to a road vehicle - a ship is operating on the water-air boundary so it can make waves and they absorb a lot of power. The bulbous bow is there to create a 'negative' wave that cancels out with the 'positive' wave from the bow, so the overall wavemaking resistance is reduced. The bulbous bow only works right at one speed when the two opposing waves are in synch.
For a road vehicle, unless you are going to go fast enough to get near the speed of sound, a knife-sharp front will never be as good as a well-rounded front - all pointy fronts are there for styling, not low drag*.
Andrew
* There's bound to be one exception, that I can't think of right now, but someone will be sure to tell me.......
