LED Conversion
LED Conversion
Postby bdosborn » Sat Jan 21, 2006 2:51 pm
I replaced the fluorescent tubes in my galley light with LEDs last weekend. The tubes kept burning out in cold weather. I tore out the guts of the light and installed three LED strips. My current draw went from 1.2 amps to 0.4 amps with the conversion. The LEDs shouldn't have any trouble with cold weather and should last 5 times longer. The light is a little more blue than I would like but it should be plenty to cook by. Don't want to add salt instead of sugar...
Images: 806
Postby billnut » Sat Jan 21, 2006 6:31 pm
:D Gosh I like that!
Nooo Darn I love that!!
Where did you get them.
Bill :applause: :applause:
Grandpa's are just Antique little Boys !
billnut
Postby Juneaudave » Sat Jan 21, 2006 6:49 pm
From the builders up north....good idea!!!
Juneaudave
Images: 380
Postby bdosborn » Sat Jan 21, 2006 7:02 pm
I got them from here:
SuperbrightLEDs
I got three of the LB1-W12 White LED strips, two interconnect jumpers, 6 mounts and two power jumpers. My fixtue is 18" long which is why I got three strips. You could use two strips with a 12" fixture and still have enough light. I used one strip for the cabin light so I knew I needed at least two strips for the galley to have enough light. I can take a picture of the inside of the light if you want a closer look. I got the two little bar lights at the bottom of the hatch from them as well. I wired them into the switch for the strip light so they all come on with one switch. The cabinet faces were in shadows without them, I have light inside the cabinets with them.
Images: 806
Postby Micro469 » Sat Jan 21, 2006 10:07 pm
Here's another source for LED'shttp://www.theledlight.com/
John
Micro469
Images: 382
Postby goldcoop » Sat Jan 21, 2006 10:19 pm
Micro469 wrote:Here's another source for LED'shttp://www.theledlight.com/
Micro-
These guys seem a little too pricey to me?
Cheers,
Coop
goldcoop
Images: 32
