Beautiful transformation!!!
Hugs,
Ratkity
doug hodder wrote:That's just the thing Cliff....some stripper, sandpaper, wire brush, rattle cans of paint and a bit of knowledge and some time, anyone can do it, especially on the relatively newer stuff, 1940 up. None of this is rocket science...just patience and effort! If someone can build a trailer, they can do a stove...There is tons of help here and on the Coleman forum to assist anyone.
doug hodder wrote:Guess what???? After all that work and great paint on the tank...it has a small weep on the filler end on it. Drips about 1 drop every 15 sec. or so. Stripped the paint off that end, found the hole...took a hand loop to see it. Hit it with a torch to maybe gas weld it up...hole got bigger which indicates it's got bigger problems.
I gave up on the welding of it....made up a batch of JB Weld, mooshed a load of it through the hole and patched the outside. It's curing now...I'll fuel it up this weekend. It's curing now. I think the big lesson here is to put some fuel in any tank and pressure it up after cleaning prior to painting to see if you have a working tank or not.
Kevin does have a back up tank for me and it's on the way. Thanks Kev! Doug
