by mskobier » Thu Dec 23, 2010 6:54 pm
Russ,
The manual that came with the furnace does not have a template, it does however give the dimensions of the hole. The hole is a rectangle
4-7/8" x 2-1/2" and it is measured from the top of the furnace down and
1-3/4" from the left side.
The furnace you ordered has more options on how to get the warm air into the CT. You stated in one of your posts you purchased the 18,000 BTU unit. The one I purchased can only be front discharged. The one you ordered can be front or side discharge. There is also a difference in the current draw between the two units. The 12000 BTU (8012-II) I purchased draws 1.8 amps. The 18,000 BTU (7920-II) you purchased draws 3.4 amps.
The battey I am going to be using is rated for 160 amp/hrs. The 50% discharge would be approx 80 amps of useable current. You can discharge the battery to much lower than that, but it tends to shorten the battery life. So my unit drawing 1.8 amps could run a total of 44 hrs. Divide that amount by the expected run time of 30 minutes per hour, and that would give me a an estimated operating time of 88 hrs or 3.6 days. Now this assumes there are no other items (lights, pump, fan etc) being run off of the battery. In your case, the time will be about half that. Assuming the same battery of 160 amp/hr rating and a 50% discharge, and same operating time per hour, you could run the heater off the battery for 47 hrs or about 2 days.
Your propane useage will also be higher due to the larger BTU rating. On these units, the BTU rating is the input rating of the furnace. In other words it is the amount of propane it will burn each hr for a given amount of heat output. The amount of heat put into the CT will be somewhat less. According to the manual that came with the unit (and downloadable from the net), the input to my heater is 12,000 BTU with the heat output of 9120 BTU. The one you have is rated at 18000 BTU with a heat output of 13,680 BTU. It should do a fine job of keeping you warm! A 20lb bottle (approx 4 gallons) of propane should last you about 2 days at the the 30 minute per hour run time. Now turning the thermostat down during the day when you are at work will extend the propane supply considerably. All of these run times are assuming that you maintain the heat at a constant level. Reducing the thermostat setting will exend all of these numbers. In my case, the 12,000 btu furnace will use up a bottle of propane in about 2.5 days. Remember, the furnace starts the blower for a couple of minutes before it allows gas to flow and be lit by the electronic ignition, then runs for couple of minutes to cool down after the flame is shut off. Again, these are worst case numbers. longer or more frequent run times will all significantly effect the propane/battery useage. So with all of that said, the battery and one bottle of propane should last about the same amount of time. In your case and heating habits, you should see similar operating time on a bottle of propane that you currently get. At least you will not have to get up in the middle of the night to light the blue flame anymore.
Insulating your CT espically the ceiling will make a significant difference in the performance of your new heater. Even if you aquired some of that aluminum coated bubble wrap and taped/stapled a couple of layers up on the ceiling would make a big difference. Maybe not too pretty, but better than nothing.
Mitch
