Where or When Jr. --Paint & New Tow Vehicle--update 5/17/15
Postby myoung » Fri Dec 31, 2010 9:13 pm
Cliffmeister2000 wrote:You could eliminate all the scrap by making some building blocks. Any grandkids? :D
Yes, but both too old and too young.
Mike Young
myoung
Images: 250
Postby Cliffmeister2000 » Fri Dec 31, 2010 9:19 pm
You are moving so fast, you won't need me on Monday! :applause:
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby myoung » Fri Dec 31, 2010 9:27 pm
Cliffmeister2000 wrote:You are moving so fast, you won't need me on Monday! :applause:
There should always be something to do or to think about.
Mike Young
myoung
Images: 250
Postby pete42 » Fri Dec 31, 2010 11:28 pm
Mike just between you and me I too love my electric screwdriver but if I have some more screws to install I do use a manual screwdriver.
sorry I couldn't help it I just thought it was funny that you had to stop because your screwdriver ran down :lol:
what would Roy Underhill think? :thinking:
HAPPY NEWYEAR :P
pete42
Postby myoung » Sat Jan 01, 2011 12:12 am
pete42 wrote:Mike just between you and me I too love my electric screwdriver but if I have some more screws to install I do use a manual screwdriver.
I'm old and weak. I don't have the strength to do it manually any more.
Mike Young
myoung
Images: 250
Postby Cliffmeister2000 » Sat Jan 01, 2011 12:28 am
Besides, building a TTT with a manual screwdriver is a recipe for carpal tunnel syndrome! :frightened:
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
Postby myoung » Sat Jan 01, 2011 2:50 pm
Today it looks like I will be able to assemble the two side walls. Here is the completed street-side wall along with the rear and front walls fitted to gauge the volume.
My wife should have no trouble standing up inside the trailer even with the pop top in the down position. I'll have to slouch a bit, however.
There will be opening windows on both sides just like in the rear.
I drilled a pair of pocket screw holes that weren't needed. Can you spot the mistake?
Mike Young
myoung
Images: 250
Postby Cliffmeister2000 » Sat Jan 01, 2011 3:22 pm
What did I win??
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
Postby steve smoot » Sat Jan 01, 2011 3:45 pm
Happy New Year Mike.
I just found your build thread. You are really doing a nice job. Can not wait to see what you do next. :applause:
I am not a complete idiot, some parts are missing...
steve smoot
Images: 62
Postby pete42 » Sat Jan 01, 2011 5:53 pm
I thought they were lighting holds to cut down on the weight....
very nice build and I am enjoying reading you post.
pete
pete42
Postby myoung » Sat Jan 01, 2011 7:16 pm
Time to buy plywood. Is your truck bed large enough to hold 4x8 sheets flat? I figure I need 15 or so sheets of 5mm Luan from HD. If you are able to help haul them, I would be most appreciative.
Just came up 6 screws short of finishing the other side framing. Tomorrow is another day.
Cheers,
Mike Young
myoung
Images: 250
Postby S. Heisley » Sat Jan 01, 2011 7:27 pm
You're moving along quickly on your trailer and it looks good. But, I am marveling at your organizational skills. You've even got a boat in there!
Postby myoung » Sat Jan 01, 2011 7:43 pm
S. Heisley wrote:You've even got a boat in there!
Actually, there are two boats that my Father built for me. One is a 12-foot lapstrake canoe and the other is a 17-foot kayak. Both are kits from Chesapeake Light Craft. Just for the fun of it, he is now working on his seventh little boat in the last four years.
Mike Young
myoung
Images: 250
Postby Cliffmeister2000 » Sun Jan 02, 2011 1:06 am
myoung wrote:Time to buy plywood. Is your truck bed large enough to hold 4x8 sheets flat? I figure I need 15 or so sheets of 5mm Luan from HD. If you are able to help haul them, I would be most appreciative.
It will haul them, but not flat. I usually put 3 -4 5 ft sections of 2x4 in the bed, to carry thin sheets at an angle without bending them.
I am ready and able to help on Monday.
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
Postby myoung » Sun Jan 02, 2011 6:05 pm
Now all four walls are completely framed. Just the two front corner pieces remain to be fitted.
Next step will be getting 5mm sheets of plywood for the skins inside and out. I think I'll just get 10 of the 18 I figure I will need because I don't want the thin sheets that will form the exterior skin lying around where they might warp.
Also, made the frames for the trapezoidal-shaped wheel wells and settled on the location and dimensions of the side door (27 inches wide nominal).
Mike Young
myoung
Images: 250
