Rod
Miriam C. wrote::lol: Attaching aluminum to foam could be as simple as some slotted hex bolts
or some T-nuts
These will bite into the foam and probably need to be glued. If you glue the foam to the aluminum and then bolt. Or maybe use some Channel/angle to cup the opening of the td for door openings.
GPW wrote:More coats on any end grain ...and any exposed areas... the more the better ... it's cheap enough ...that's your "insurance"If you sand it (lightly ) after, it gets smooth
Auntie M .... er, I dunno ' ??? Might rip out over time ... and I get the blame ...
