My attempt at building a Teardrop...........
Postby loy54 » Mon Dec 13, 2010 10:14 am
Not making much progress on the tear......but am working on getting a warmer place.........I've got an old house on my property that I've been slowly trying to turn into a garage/shop..... it looks like a garage from the outside.....I put sheet metal on the walls and roof and installed a garage door........The inside is a different story......am having to take out the wood floor and some walls....... can't afford to pour a concrete floor rite now..... so I'm covering the ground with some Shell that I'm getting from a nearby strip pit.....am getting close to getting a workable area for my teardrop :worship:
loy54
Postby StPatron » Tue Dec 14, 2010 12:56 am
Lloyd A wrote:.....am getting close to getting a workable area for my teardrop :worship:
Great! You'll enjoy that.
I've been enjoying watching your build, nice job.
StPatron
Images: 297
Postby loy54 » Sun Jan 09, 2011 5:55 pm
Way to cold to work on the tear today.......high of 27 degrees.....small propane heater not cuttin it :thinking:
loy54
Postby StPatron » Mon Jan 10, 2011 2:19 am
I hear ya, my work has also been shelved until it warms up.
Supposed to warm up on Friday, hope so.
StPatron
Images: 297
Postby loy54 » Mon Jan 24, 2011 1:15 am
How much Epoxy will it take to seal my 5'Wx9 1/2'Lx4'T tear............................1 gallon, 2 gallon?.... :thinking:
loy54
Postby aggie79 » Mon Jan 24, 2011 2:18 pm
Lloyd,
I bought a two-gallon kit and had about a half gallon left over. (As I understand it, it has a long shelf life.)
My teardrop is 4' tall x 5' wide x 10' long. I put one coat on the bottom of the trailer floor - on top of two coats of CPES - and two coats on the exterior ply walls and roof.
First thing I did was lightly sand the ply, filled the screw holes with Plastic Wood, then sanded the fill, followed by the epoxy. This picture is after the first coat of epoxy:
Take care,
Postby Pizzaguy » Tue Jan 25, 2011 1:48 am
I got the 3 gal kit from Raka. I used ALL of it on my woody. Even had to get a small can from West Sytems for a few odds and ends at the end of the build.
Pizzaguy
Postby StPatron » Tue Jan 25, 2011 3:08 am
Tom's advice is always top-notch and should get you at the very least in the ballpark or more than likely nail it.
With epoxy, or most any coating, total surface area coverage is always a guesstimate. It depends on the absorption rate of the substrate, how thick you apply it and how many layers you apply.
Consulting the manufacturer is also a good idea.
StPatron
Images: 297
Postby loy54 » Tue Jan 25, 2011 5:27 pm
Thanks guys..........You've been a great help.................. :ok:
loy54
Postby loy54 » Sun Apr 03, 2011 6:51 pm
Got my Epoxy(3 gallons) the other day........now in the process of prep work.............. :thinking:
loy54
Postby loy54 » Sun May 22, 2011 8:37 am
Well its been a while....... I'm getting pretty close to completion... mostly like installing the hardware....door hinges,roof vent, etc.....
Had a few mishaps with my epoxy and paint(they don't mix)....got the brite idea to mix some red paint with epoxy to give it a red tint (BAD idea, looked good but wouldn't dry for crap...stayed tacky). Ended up sanding that off, but left a little red in the woodgrain..I thought it looked a little like red cedar, so I left it like that and re-epoxied over that........some might think it looks like crap, but I think it looks pretty good....Will post pics later............................
loy54
Postby loy54 » Mon May 23, 2011 9:46 pm
Not complete, but getting closer ............
loy54
Postby Wanna Be » Tue May 24, 2011 10:15 am
Talk about an UNmatchable paint job !!!!!!!
Practical for a teardrop, as it's one of a kind !!!
Stay safe, and have fun.
Wanna Be ;)
This nation will remain the land of the free only so long as it is the home of the brave.
~Elmer Davis
"Well, if you can't believe what you read in a comic book, what can you believe?" ~ Bullwinkle J. Moose
Also I am a professional spelling butcher.. I don't carry a dictionary and my spell check is broke!!
Wanna Be
Postby gregp136 » Tue May 24, 2011 9:55 pm
Cool paint job! I love the wood grain showing through and red happens to be my favorite color. I am also lover of a creative "off beat" kind of style. Keep it-- all that matters is that you and I like it. Greg likes it too!
Laurie(the artist) & (Greg)
gregp136
Images: 100
Postby Woodstramp » Wed May 25, 2011 12:43 pm
Lloyd,
You need to change the thread title to "Not and attempt....I DID IT!"
Good work. I like the finish too. Wish mine was as far along as yours is...
Woodstramp
