Ira wrote:We don't have a Menard's down here, but that Coroplast/Correx sounds like real interesting stuff.
powderburn wrote:s4son wrote:How about making 1 X 2 frames and covering with a fabric. Now you have me thinking. How about wooden frames with sleeves sewn like big tubes. You put the frame together and slip the fabric over it like a big sock. you could make it any color you like, change it when you want and wash it when it gets dirty.
Scott F.
Here you go s4son
Already built and ready to go.Just add your own cloth and you can corral yourself right in.![]()
http://www.mytscstore.com/detail.asp?pc ... uctID=9383
angib wrote:Seems to me you'd need a double-decker system. The largest panel size you can use is 3'9" high (that will fit across the teardrop inside) by about 3' wide (that will fit vertically through the teardrop door). I know the inside of the teardrop is bigger than that, but I don't think you'll get anything much bigger through the door.
Ira wrote: and once every 3 months, maybe get intimate with my wife.
goldcoop wrote:Every 3 months!![]()
YOU are a lucky man
Ira wrote:A 2' wide by 6' panel won't fit?
