O.K. guys guess I'll come out of the closet...
I have a 5 x 10 sheet of this polymax stuff and three sheets of 4 x 8 comming. Am going to use some Marine GOOP on it to seal my trailer. The stuff is nearly industructable. Won't even burn worth a hoot. GOOP will not melt it but if you take a small wire brush and rough, well it won't rough up either, but the rotary brush in a drill will create small groves in the PolyMax that will hold a good seal. The GOOP is, well for lack of a better word, malleable so it seals and sticks without breaking when put between aluminum and the PolyMax. This you will not beleive, but hot melt glue will almost adhere to it, well it does not give what you would call a good glue up. The high temperature kind that is. Solvents have no effect on it and can be used to clean it. If you melt the stuff it retains its original properties that is, flexible and slick as you know what.
I am just about ready to apply it to the roof and sides will advise in a couple weeks how this stuff goes on.
By the way it can be cut with a pair of scissors.
O.K. MadJack it's all out in the open now.
Oh - by the way Duct Tape won't even start to stick to PolyMax
