Can anyone tell me what thickness the tubing wall should be?
I'm hoping to get this project done before the next outing.
Thanks,
Mike
firemaniac wrote:Well, at least on mine, behind the 2 feet that stick out the front there are 6 more feet that continue under the trailer, which is securely bolted to two 4 foot long 2x2x.250 angle iron on either side, each piece of angle is bolted to the main frame of the trailer under the cabin.
At the front of the "A" frame the original ball mount is inverted and the 2x2 tube is bolted to the inside of that.
All of this was done using 1/2", and mostly 3/4" hardware.
