I think your Squidget PopTop design is a good one and am looking forward to seeing its construction. Please keep us posted!
cracker39 wrote:My son-in-law came over this morning to weld on the tongue, so most of the welding is finished. I just have to get my neighbor to help me turn the frame back bottom side up (it weighs 240-250 lbs as is) so I can weld some additional bracing beneath the piece of tubing that the coupler bolts to and coat the bottom with Rust Bullet. The weather here in Florida has turned cool (we expect 27 by morning), so the Rust Bullet application will be slow this week. It can be applied as low as 50 degrees and it may get warm enough by mid-day tomorrow to apply a single coat, but I’ll probably wait until Friday when it should get up to 60 degrees. It will take four or five days to get it done as I won’t lie on my back to paint beneath the frame this time. I’ll put the two coats on the underside while that side is up on blocks, then turn it over to put the final two coats on the top side. I expect to have the floor finished by the 19th or 20th, then I’ll put on the axle and get it moved to my portable garage out back to work do the rest of the construction.
Larwyn wrote:Yep, flipping that frame alone can be work. I threw together a quick rotisserie when I painted my frame. It's just a few pieces of 1/2" all thread, some 1/4 by 2 inch strap, and my pipe stands. It made the painting process a lot easier to handle. Most of the parts have been cut up/re used after the frame was finished. It was worth it to me and provided a bit of entertainment at "beer thirty" spinning the trailer and guessing where it would stop. Kind of a coin toss, only using the trailer frame instead of a coin........
Steve_Cox wrote:Hi Dale,
Really like that bumper/spare set up. Nice work. I welded flat stock on my teardrop frame open box ends that were on the tongue and rear bumper. You made easy work of that with your foam and epoxy technique, very nice.
