starleen2 wrote:So Jon P - ya' worried about drag? we need to know what you are towing with - It makes a difference. I have towed with a jeep commander and a jeep wrangler - with the same trailer - And I can tell the difference between the two - one is narrower and shorter than the trailer - the other same width and height of the camper.
planovet wrote:Sometimes I think we tend to over-think this stuff. All the engineering mumbo jumbo tends to fly over my head (no offense to those who are engineers). My tear has a curved front surface, not because of aerodynamics or the "drag coefficient" but because I liked the look better.![]()
Bucko6 wrote:For what it is worth, I think your MPG expectations are too high. My tow vehicle is a full size crew cab pickup. On the highway empty, I get about 20 MPG. When I tow my 30' travel trailer it drops to 10 to 12 MPG. When I tow my teardrop, I was only getting 14 to 16 MPG. Keep in mind I run 70 MPH empty, 60 with the 30' and about 65 with the tear. Profile is important, look at how manufactures round the front profile of new factory travel trailers. I think overall frontal area is important too. My tear could hide behind my pickup but the air behind the tow vehicle will drop back down and meet your trailer head on. For your best shape, think airplane and keep the frontal area small. My guess is no matter what you do, you are going to knock off about 25% of your unloaded MPG.
kennyrayandersen wrote:
However, less well known is that the front matters some, but the back is where it's at. The back has much more influence regarding the overall CD than the front. In the front the air builds up and makes it's own pseudo shape, but a flat in the back causes tons of turbulent flow (drag).
PaulC wrote:In a perfect world all the talk above makes sense BUT your trailer/TD will always be travelling in "dirty" air. This argument has been raised here to the point that my best advice to you is to build it, put the drawbar on the front of your tow vehicle and push the thing down the road. Then, and only then, will aerodynamics be of any effect.
Cheers
Paul
