DrJerry wrote:Old boatbuilders trick: Use 1/8" plywood, score it every inch or so..shallow sawcuts will do.
oklahomajewel wrote:Now I'm scared !!!
Is the hatch always this hard, have this many problems?
I'm starting to wonder if I should get a contractor.....
mikeschn wrote:oklahomajewel wrote:Now I'm scared !!!
The hatch is not hard. But if you cheat you may run into problems. Use a robust design and the right materials, and it'll be easy as pie!
Users browsing this forum: Google [Bot] and 14 guests
