For those of you who are following my other build, The Justintime, you know that I'm also planning an ultralight composite trailer.
Unlike the Justintime thread, this one is going in "real" time. I started this build just last week (1/25/11)
I hope that people will chime in here with advice....because like the title....I'm making this up as I go along.
The design
A shrunk Grumman 2. (9'2" length).
63" outside width.
"A" frame trailer.
2K axle w/ standard springs.
750 lbs, dry weight.
Step one, making a "buck" of the door, so I can make a mold, so I can make parts.
Door design:
Is really is symmetrical...I just made a quick sketch for the measurements.
3/4" MDF base:
Sides and bottom:
Top arch, MDF stacked to make the curve:
This is the face skin, so Bondo and sanding is the name of the game.
High fill primer and more Bondo:
MDF is not perfectly flat.....wet sanded with a long board.....look at the ridges that show up:
Wet sanded 800 grit:
(is was still a little wet, the marks at the top of the picture are not scratches)
Now for the questions...
What kind of paint should I use for the top layer of the buck?
Automotive, plain acrylic/Krylon, or gel coat?
This will be sanded and buffed to a high gloss to get a mirror surface on the mold.
Lee
