Ive cut oak on my table saw and it left black marks on the wood..I ended up sanding it off. Will the router leave same type of marks?
Do I need a special type blade?
rbeemer wrote:Heikki,
The burn from your table saw is probably from the the build-up of pitch or blade getting dull.
When using the router do multiple passes - If you are rounding the edges a bit with a bearing should take care of any burning. I have routed hard maple, birch and oak and have not noticed any difference when using the router. Sometimes burning will happen when you try to take a too big of cut. Do not try to go any faster than you are comfortable.
Just my thoughts,
Classic Finn wrote:
By the way the table saw is new as well as the blade.alignment maybe?
planovet wrote:All my cabinets are Red Oak and I used a router on all of them. Go steady and you should be fine. If you bog down, that's when you tend to get the black marks. They will usually sand out though!
I built a homemade router table to help with the thinner pieces. It made a world of difference.
Ageless wrote:The 'burning' on oak is due to the content of tannic acid in the wood. A slower feed and less depth of cut reduces the build-up of heat.
Users browsing this forum: Bing [Bot] and 5 guests
