Trimming Aluminum
Trimming Aluminum
Postby len19070 » Wed Feb 01, 2006 6:19 am
I just completed the first trailer I have ever built with aluminum sides. Up until the day I trimmed, it was bothering me as to what to use to trim it with. I had read about all the tools people on this board had used with the Rotozip leading the way. Armed with every tool I owned after laminating the sides I started to trim.
First I started with a Router w/speed control, a lot of mess and a really bad job.
Then on to my Rotozip, did a very good job but very wild with poor control just like all Rotozips without a jig.
Then I went pneumatic. I got my new $20 Harbor freight air saw
http://www.harborfreight.com/cpi/ctaf/d ... number=113
Worked great. I just laid the blade over the roof sheathing using it for a guide and went to town. Nice & slow with lots of control. I think the high speed was the key.
If you have air, for $20 I think this is a great option.
Happy Trails
Len
len19070
Images: 24
Postby toypusher » Wed Feb 01, 2006 6:25 am
Len,
Although I have never used them, I hear that air shears are good too!
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=36567
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=36568
I just cut my AL when I cut the sides (as a sandwiched stak)
toypusher
Images: 324
Postby len19070 » Wed Feb 01, 2006 6:33 am
That makes sense Kerry. But I'm an old Formica guy and I was treating the aluminum like that.
The air shears work great. I use them at work all the time. It was an accident I had that air saw. I was in HF that morning when they went on sale. When I saw it, for $20 bucks I just had to get it.
Happy Trails
Len
len19070
Images: 24
Postby toypusher » Wed Feb 01, 2006 6:57 am
len19070 wrote:......... When I saw it, for $20 bucks I just had to get it.
I know what you mean!
toypusher
Images: 324
Postby gman » Wed Feb 01, 2006 12:05 pm
I have one that uses standard hacksaw blades, works on steel for a while but then snaps them, may work on aluminum better.
Junk is something you've kept for years
And throw away three weeks before you need it.
gman
Postby Steve_Cox » Wed Feb 01, 2006 1:25 pm
Len,
That air saw cuts at almost 4 times the speed of my Milwaukee sawzall. Bet that aluminum cut like "buttah"
Steve 8)
Steve_Cox
Images: 196
Postby templou67 » Wed Feb 01, 2006 4:22 pm
One of the many things I use an air saw for, is trimming aluminum trailer skins and it is the best tool for the job. The only thing is that I use cutting wax on the blade and that makes it glide right through.
templou67
Postby len19070 » Thu Feb 02, 2006 6:30 am
Like a hot knife through "Buttah". ooh, I'm getting all "fa-klep-it-a". It is the speed that does it.
Happy Trails
Len
len19070
Images: 24
Postby fornesto » Thu Feb 02, 2006 5:16 pm
I had the exact same experience. The air sheers did the job, made BIG curly-cues. My router never forgave me after that embarassing day. Cutting out the doors was a bit more of a challenge though. Next time, I would do the sandwich method from the get-go.
fornesto
Postby bledsoe3 » Thu Feb 02, 2006 11:44 pm
templou67 wrote:One of the many things I use an air saw for, is trimming aluminum trailer skins and it is the best tool for the job. The only thing is that I use cutting wax on the blade and that makes it glide right through.
Templou67, Let me be the first to say welcome. I see you've been around a while but you finally made your first post. Let us all know if/what you're building. And if you are, post some pictures. Jack gets cranky if you don't.
bledsoe3
Images: 112
router
Postby Finntec » Fri Feb 03, 2006 5:45 pm
We used a router too. It creates a huge mess, but the seams were perfect. I just went slow with a new flush cut bit and wore protection from the hot, flying metal. Maybe for the next one I build, I'll get one of the cutters from HF. Sounds much less messy. :applause:
Former owner of a '05 Homebuilt TD & '87 Scamp
2012 Home built 10' Teardrop.
Finntec
Images: 28
