Green Lantern- now with awning!!!
Postby starleen2 » Tue Feb 22, 2011 8:41 pm
Finally – The final coats of epoxy are applied – Still need to sand some runs out and level a few places – but the edges are sealed, rounded and all seams are reinforced with fiberglass tape. I found it easier to sand outside while the weather is cooperating! I’m going to let it sit to cure for a day
One thing I learned from this: wear long sleeves when sanding fiberglass - it does tend to get a little itchy
starleen2
5th Teardrop Club
Postby Ratkity » Tue Feb 22, 2011 8:49 pm
Nice progress!!
For the fiberglass sanding itchies: get a cotton ball and put some baby oil on it (vegetable oil works too) and wipe your arms in the direction of the hair growth with oil-soaked cotton ball. That'll remove the fiberglasss pieces. Then take a bath (or lay out in the sun hehe).
Hugs,
Ratkity
Ratkity
Postby Rlowell » Tue Feb 22, 2011 9:13 pm
:applause: :applause: Looking great!!
Rod
Plan your work...work your plan...at least that's the plan. Oh, just do it anyway!
gallery/image_page.php?album_id=1425&image_id=76342
Rlowell
Images: 42
Postby aggie79 » Wed Feb 23, 2011 8:43 am
Scott,
The Green Lantern continues to impress! Beavers Bend certainly looks achievable.
After you've given it some time, I think it would be good to hear your thoughts about epoxy. I known you've used other methods.
Take care,
Postby starleen2 » Fri Feb 25, 2011 5:05 pm
Sanding is done – now for the first color coat – you guess it – ALL green. Did away with the two toned scheme and went with all Coleman green. The front and rear graphics will break up the color
Now to play the waiting game for the paint to dry - then install the windows door and next comes wiring the trailer harnesses and lights
starleen2
5th Teardrop Club
Postby Rlowell » Fri Feb 25, 2011 5:40 pm
starleen2 wrote:Sanding is done – now for the first color coat – you guess it – ALL green. Did away with the two toned scheme and went with all Coleman green. The front and rear graphics will break up the color
I love it!!!!! That is a color you can live with!! Way to go!
Rod
Rlowell
Images: 42
Postby Cliffmeister2000 » Fri Feb 25, 2011 5:46 pm
Yup. It's green, alright! :shock:
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby droid_ca » Fri Feb 25, 2011 6:29 pm
that color is perfect way to go
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby Loader » Fri Feb 25, 2011 7:03 pm
Looks great Scott!
Earl & Kerry
"Loader"
Loader
Images: 245
Postby Miriam C. » Fri Feb 25, 2011 7:23 pm
:woohoo: :beautiful: Shinny! I really like it a lot! :thumbsup:
Postby KenC » Fri Feb 25, 2011 8:11 pm
Great color, can you tell me where you got the paint :applause:
KenC
Images: 41
Postby james worley » Fri Feb 25, 2011 8:32 pm
Looking good Scott! its so shinny looks like automotive paint.
james worley
Images: 51
Postby aggie79 » Fri Feb 25, 2011 8:46 pm
:thumbsup: Love the color, Scott.
The Green Lantern is going to be a big hit at Beavers Bend and other future outings.
Please put me on the list for a personal tour at BB.
Postby starleen2 » Fri Feb 25, 2011 9:20 pm
Well folks here’s the secrete – The paint is from Tractor Supply Company and its Valspar Tractor & Implement High Gloss Enamel, Oliver Green. It a close match to coleman green. I used it on the interior bedding platforms and its super tough – I’ve sprayed it with water, armor all, and even sanded it – tough stuff once it’s cured. I guess it has to be to used on farm equipment. It’s an oil based paint so it’s kinda a mess to deal with as far as clean up – but it’s defiantly a bulletproof finish (Please don’t test it by firing bullets into my camper!) It takes a while to cure – but it seems to level itself out – and I applied it with a foam roller!
starleen2
5th Teardrop Club
Postby doug hodder » Fri Feb 25, 2011 9:30 pm
That is one green trailer Scott...look at it this way...it's camo for hiding on the golf courses! Doug
