Welding thingy help
Welding thingy help
Postby 4123 » Fri Feb 25, 2011 12:21 am
This is to all you welders out there. I've got an old Forney welder from the 50s. This is a piece/part that came with it. Can someone tell me what the heck it is? Thanks, Ron
:thinking:
~~~Ron & Olga Christianson~~~
http://www.museumphones.com
"Consider It ALL entertainment"
Images: 50
Postby PaulC » Fri Feb 25, 2011 1:15 am
Ron, that's one of the arc welder cutting doohickies that used to be all the go. They where going to replace oxy cutting apparently. Sorry for such a technical description :lol: I couldn't help myself.
Cheers
Paul :thumbsup:
http://en.wikipedia.org/wiki/Air_carbon_arc_cutting
PaulC
3rd Teardrop Club
Images: 36
carbon arc torch
Postby djayh » Fri Feb 25, 2011 6:22 am
djayh
Images: 22
Re: carbon arc torch
Postby PaulC » Fri Feb 25, 2011 6:52 am
djayh wrote:its a carbon arc torch
http://www.youtube.com/watch?v=DYnsCXVsJsw
That's what that doohickies called ;)
They where used to cut various other metals.
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Postby angib » Fri Feb 25, 2011 5:59 pm
PaulC wrote:That's what that doohickies called
Indeed - Dr Frankenstein spoke highly of the one he used to trim the length of the neck bolt on his monster.
angib
5000 Club
5000 Club
Images: 231
Postby mcspin50 » Fri Feb 25, 2011 6:06 pm
Lil M.
In every walk with nature, one receives far more than he seeks. - John Muir
Generic Benroy Build Journal here - My LilScamper Update Journal here
The Lily Pad...Image My LilScamper...Image Image
mcspin50
Images: 158
Postby starleen2 » Fri Feb 25, 2011 6:14 pm
You can also use them to weld with - but you'll need a filler rod
starleen2
5th Teardrop Club
Postby hotrod » Fri Feb 25, 2011 6:45 pm
wow looks different than my carbon arc torch! which by the way work very well for certain applications like back goudging, cutting out bad welds or cutting something apart that you do not want to destroy... takes a little skill but our shop wouldnt function without them....
Paul
hotrod
TILT
TILT
Postby hotrod » Fri Feb 25, 2011 6:57 pm
http://www.youtube.com/watch?v=KCoogBhq18w
heres the ones we use... handy things, be sure youve got a DC welder capable of 300 amps...
Paul
hotrod
TILT
TILT
