I'm curious as to what axle you have. And what do you believe happened to the cotter pin?
Did the manufacturers forget to put one in.
Wayne
Conestoga wrote:Blessings to you all.. and extra for Bob Henry.
This forum may have saved me from disaster.
Slim chance that it will happen now, so we'll never know for sure ;-)
Yesterday I pulled the hubs off my trailer.
There was no cotter pin on the driver's side.
Although it was still holding solid, it was a mess.
It had apparently gotten so hot at some point that the nut and washer
were nearly fused to the bearing.
(Starboard side was in good shape, so it wasn't driver error.)
bohemian wrote:Bobhenry
Ive heard about adding to much grease. And the effect it has.
I have on my trailer the through the spindle grease filler.
They say to fill until the grease flows out the outer barring.
Does this put to much grease into the bearing area. And if so should I be worried about it?
Wayne
Conestoga wrote: Oh, by the way, 30 min. job? That's pro! I spent 30 min. just
trying to figure out how to get the seals out.![]()
I tore up one of the seals trying to get it out of the hub.
Why would HF carry bearings but not seals?
sdtripper2 wrote:Bearings and Seals/Covers
There have been many threads on what to do about bearings and
Seals/Caps for the HF trailers. The discussions are around the metric
bearings that these trailers use. As of this writing I have not gotten a
satisfactory listing of maintenance part #s for the trailers here that
we have been touting. I have listed an incomplete list that may
help you get more information from HF for on going maintenance
for your trailers. These numbers may need revising.
Note: Check your trailer Owners Manual
for bearing and seal maintenance prior to running your trailer as well as on
going considerations of maintenance time frames. As a rule it is considered
wise counsel to check & or consider repacking wheel bearings before first use.
Tutorials for packing Bearings are shown here:
http://tinyurl.com/h5goy
http://tinyurl.com/erf43
http://tinyurl.com/e97an
http://tnttt.com/viewtopic.php?t=24508
Metric Bearings and seals from these companies:
Note: Harbor Freight trailers use metric bearings and seals:
Some want and have found alternate sources for these metric parts:
http://www.epm.com/pg23.htm
http://www.rocketseals.com/
http://www.anyseals.com/
http://mdmetric.com/
Harbor Freight Customer Service Representative
Monday-Friday 9:00 - 5:30 EST at 1-800-444-3353
HF model 90154 ITEM 90154-8VGA HF 1175 LB. $239.0
HF CAPACITY 48" x 96" FOLDABLE UTILITY TRAILER WITH 12" WHEELS
Bearing type .............................(28079 BEARING 25M 284 2.85)
Bearing part number..................ITEM 93834-0VGA
Cost about................................$4.99
Need 2 Bearings per wheel 4 per trailer.
Bearing seal/cap.......................(27737 GREASE SEAL 229 1.00)
Bearing seal /cap part #............ITEM 93833-0VGA
Cost about................................$2.99
Need 2 per trailer.
"Cliky"Here > is a thread for this trailer You
will also note a link here that will show a "Servicing Wheel Bearings"
Tutorial.
HF model 40597 ITEM 40597-0VGA HF 1800 LB. $399.99
HF CAPACITY SUPER HEAVY DUTY 48" x 96" UTILITY TRAILER WITH 5 LUG
12" WHEELS AND TIRES NOT FOLDABLE
Bearing type .............................(Unknown special order HF)
Bearing part number..................(HFVendor# 11239 set of 4 bearings)(Anyseals.com 30205 bearings)
Cost about................................$15.89
Bearing seal/cap.......................(Unknown special order HF) 30x52x10 marked on the seal
Bearing seal /cap part #............ (HF Vendor# 13922) (Anyseals.com NO. is 24640 OSA)
Cost about................................Unknown
Need 2 per trailer.
Info (Geron Page 3 of this thread)
bobhenry wrote:... Drag hub towards you and the nut will bump the inboard bearing and it will bump the seal....
Conestoga wrote: The bearings are metric,
and so far the only place that I've found them in stock are at Harbor Freight.
bdosborn wrote:Oh wow, this is timely. I just bought a complete bearing kit for my flexiride axle for $18.95. Bearings, races, seals, dust caps, locking washer, lug nuts - the works for both sides.
Southwest Axle Linky
I was just going to buy seals and pack the bearings but the kit was so cheap I'll probably just replace everything.
bobhenry wrote:Conestoga wrote: Oh, by the way, 30 min. job? That's pro! I spent 30 min. just
To remove the seal with minimal damage remove cotter pin, nut ,washer and outer bearing. Reinstall just the nut about 3 or 4 turns. Drag hub towards you and the nut will bump the inboard bearing and it will bump the seal. Turn the hub 1/2 turn and bump again if seal has not popped out
turn 1/4 turn and bump again, continue until it pops out. If you are gentle but persuasive you will not damage the seal. They do recommend a new seal when repacking but having never damaged one I have never bothered to replace one.
Miriam C. wrote:bobhenry wrote:Conestoga wrote: Oh, by the way, 30 min. job? That's pro! I spent 30 min. just
Hey Bob, is there an easy way to get that seal back on without trouble?
