I need some cleaning help
Postby dh » Thu Feb 24, 2011 6:06 pm
We like to try new DO recipies in the oven durring the winter so we arn't learning in ''the field''. I degress, the old lady made a breakfast cassaroll in the DO and forgot to oil it first, I'v had it soaking for two days and the chees and egg arn't comming off. any ideas before I get out the dish soap and have to reseason?
dh
Postby rbeemer » Thu Feb 24, 2011 6:24 pm
I think if you have had it soaking for this long you are going to have to re-season.
Have you tried either a pressure washer or putting water in and stick it in the oven and trying to "boil " the water.
These are just my best guess my own experience has been scrubbing with a plastic pad or bamboo brush that you use on a wok and then seasoning
Rick
If ducks had scales, would fish quack?
rbeemer
Postby sdakotadoug » Thu Feb 24, 2011 8:33 pm
Putting it back in the oven with some water and boiling it gets my vote. Worked on the one occasion one of my daughters put one away for me and I discovered it a couple of days later. Doug
sdakotadoug
Postby Kevin A » Thu Feb 24, 2011 10:32 pm
sdakotadoug wrote:Putting it back in the oven with some water and boiling it gets my vote. Worked on the one occasion one of my daughters put one away for me and I discovered it a couple of days later. Doug
I agree, bring some water to a boil and scrape the stuck on food with a plastic scraper. Empty the DO and rinse with some clean hot water, dry the DO and oil it lightly. It'll be ready for your next cook-out
Kevin A
The other guy
Images: 289
Postby bobhenry » Fri Feb 25, 2011 8:10 am
Yep !
Did toasted cheese in a C.I. skillet last night and there is nothing in my book worse than stuck on burnt cheese. Just boiled for about 2 minutes and scrubbed it clean with a scotch brite pad. It was quick and easy then dried it on the burner and re oiled. It's ready to go again.
Postby dh » Wed Mar 02, 2011 10:22 pm
Thanks for all the replies. Boiling water did the trick. :thumbsup:
I did go ahead and oil the inside and "bake" for about 30 min.
dh
sticking
Postby doitright » Thu Mar 03, 2011 9:28 pm
boiling water works great when things stick in cast iron. If I have to do the boil, next few times I will deep fry or cook a lot of bacon in it. Your cast needs oil all the way through the cast iron to keep it non stick. When you season the cast iron it puts on a very thin coat of oil in the cast. The more you use it the better. I keep from boiling in mine or cooking high acid foods until it has at least a year of good frying.
doitright
doitright
REAR DOOR CAMPER
1959 REAR DOOR SCOTTY
doitright
Images: 38
Postby bobhenry » Fri Mar 04, 2011 7:41 am
That different.....
I boil mine after each use to eliminate the need to scrub the hell out of the cast ( and the built up seasoning) with a scotchbrite pad.
I boil for only about 2 minutes then wash in warm water only and rinse. I will then set it back on the burner to dry completely and re oil while warm.
I can fry an egg in 13 of the 14 skillets I own! :thumbsup:
Postby bobhenry » Fri Mar 04, 2011 7:48 am
On a "kinda" related question. I have one skillet that all but refuses to season and finally I decided work or die. I left it on the burner to super heat bone dry. I then took a big blob of crisco on a thick paper towel pad and smeared the insides while hot hot hot! We smoked up the kitchen a bit but it appears to have worked the gray is gone and it is looking better.Has anyone else seasoned a pot on the stove top or over the campfire
Postby bobhenry » Fri Mar 18, 2011 7:12 am
Cleaning spin.....
I was trying to remove some dried on vegatable soup leavings on my favorite wagner square skillet last night. When I went to pick up the scotchbrite pad I usually use it had died. Yep! it was a tattered rag of a thing more like wet toilet paper than a scrubbing aid, so I tossed it and grabbed for another in the appropriate drawer. There were no more :x .
Well it wasn't gonna come clean without a little help it had already been boiling for 4-5 minutes.
As I glanced around I spied one lone onion in the mesh onion bag :thinking:
Nylon mesh Hummm! cut off the tags and the little metal crimp on the bottom and shook a couple remaining onion skins in the trash. I then wadded it up to wash the skillet.
Worked like a charm ! It is now rinsed and dried and tossed in my D.O. ditty bag with the outdoor cooking supplies :D
Return to Cast Iron
