Waterproofing
Waterproofing
Postby nrody » Mon Mar 07, 2011 9:56 pm
Has anyone used spray on bed liner to water proof their trailer?
nrody
Nancy
nrody
Marty or Larry Boehme
Postby Guy » Mon Mar 07, 2011 10:07 pm
One of the Boehme brothers has....the one who edits and publishes the TOW newsletter.
Regards,
Guy
Guy
Images: 44
Spray on bed liner
Postby nrody » Mon Mar 07, 2011 10:45 pm
Any thoughts on this application to waterproof the underside of the trailer? Good, bad, or otherwise?
nrody
Nancy
nrody
Re: Spray on bed liner
Postby grant whipp » Tue Mar 08, 2011 2:17 am
nrody wrote:Any thoughts on this application to waterproof the underside of the trailer? Good, bad, or otherwise?
It works well enough ... just a bit too heavy for my liking and considerably expensive (even the rattle-can stuff, if you want an good enough coating). I much prefer the black asphalt-based concrete sealer, myself ... been using it a good l-o-n-g time and never had a problem with it!
Good Luck, and as always ...
CHEERS!
Grant
grant whipp
Teardrop Manufacturer
Images: 117
Postby nrody » Tue Mar 08, 2011 7:36 pm
Is there a brand name you would suggest and where I can purchase it please? :)
nrody
Nancy
nrody
Postby LDK » Tue Mar 08, 2011 9:52 pm
I used the Henrys brand. The Henrys 201 I think.
LDK
Waterproofing
Postby nrody » Tue Mar 08, 2011 11:35 pm
Thank you! All help is greatly appreciated!
nrody
Nancy
nrody
Re: Marty or Larry Boehme
Postby Mightydog » Wed Mar 09, 2011 12:46 pm
Guy wrote:One of the Boehme brothers has.
You're thinking of Marty Boehme's trailer:
Rod Glassett also covered one of his with bed liner:
As Grant mentioned, I understand it adds weight. Other than that, it's good waterproofing!
Mightydog
Postby Noob » Wed Mar 09, 2011 10:14 pm
Mightydog wrote:
Guy wrote:Image
Little OT , but those are best folding chairs ... roof and clever folding w/ shoulder straps.
Bend the knees, watch the trees, 5$ please.
Noob
Postby cracker39 » Thu Mar 10, 2011 10:06 am
For sealing the underside of the floor, lots of folks (including myself) use the Gardner's roof coating in the green can. I put a coat of epoxy resin on the plywood first, then apply a coat of the roof coating. Finally, I stick on a 3/4" layer of Rmax foam insulation and caulk the seams for added waterproofing, but also to insulate the floor too.
For protecting the skins, prior to painting, I coat the plywood with epoxy resin and sand very lightly, just enough to smooth ouf any imperfections before priming and painting with latex floor and deck enamel. The original Squidget is 5 years old and the new owners told me a few months ago that the paint is still in good condition. The resin I use is Bondo brand from Home Depot at about $37 per gallon. One gallon will easily do a TD.
Dale
cracker39
Images: 233
