i think i may be changing my whole shape. i am thinking of going really simple, and do as you did. just the 4 walls and then the roof will just lift up, so you can stand inside. how easy will thta be! and if you have to just jump inside for a quick sleep, you don't even have to lift up.
with out any cutting at all. i think this would be super easy to do. and even easier to lay the canvas down with the shape rectangle vs curved.
couple of dowels to hold the roof up, or better yet, stryrofoam holders. canvas sides just like a pop up or i could finally recycle one of my old tents, and cut that out to use. recycled and cheap.
the only thing needed for cut outs will be the door/ my window is going in the door. but if i just make the back wall an open out door then i won't need to cut much at all, just the window and afix a hinge.
since it will then only be 4' high, it won't have too much added wind drag type problems slowing my down and wasting gas.
but the whole idea is so darn simple even i can do this almost alone, if not alone.
i now have a totally new excitment going on now. could even sand the joining edges and give it a more rounded look.
