Where or When Jr. --Paint & New Tow Vehicle--update 5/17/15
Postby myoung » Sat Mar 12, 2011 9:27 pm
Cliffmeister2000 wrote:Very nice, Mike! I hope to see lots of detail on how you weatherproof the door. :thumbsup:
Cliff,
I'm not planning anything elaborate. There is a threshold and an aluminum trim strip with drip edge and pliable rubber gasket at the bottom. Along the sides, I'll put a compressive rubber gasket inside an overlapping and perhaps rabbeted trim strip around the other three sides.
If it ever becomes necessary, I could put a drip gutter over the door and edge the outside of the door with flat stock overlapping the sides and top.
Might I need to do more?
Mike Young
myoung
Images: 250
Postby Cliffmeister2000 » Sat Mar 12, 2011 11:06 pm
Cliff,
Probably not, as you plan to garage it. I'm not that happy with my weatherstripping. As soon as I find a better solution, I will change it. As meticulous as you have been, I'm sure what you do will be perfect. :thumbsup:
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby myoung » Thu Mar 17, 2011 8:22 pm
Today it was time to box in the deflector in front of the pop-up top.
By placing one 3/4-inch strip horizontally on the roof top, I have the added advantage of a support under the pop-up when it is in the down position. I'll put 5mm Luan along the top and the backside of the deflector to allow only a small gap between the deflector and the pop-up, which should be easy to seal with a strip of rubber.
The deflector allows me to frame the opening for the linear actuator and to create an effective seal along the front edge of the pop-up.
Happy St. Patrick's Day. I'm 1/8 Irish by virtue of my great grandmother, Anastasia Murphy.
Mike Young
myoung
Images: 250
Postby emiller » Thu Mar 17, 2011 8:58 pm
:thinking: oh :thumbsup: aw
emiller
Images: 157
Postby 2bits » Thu Mar 17, 2011 9:08 pm
I'm not Irish, but that is some sweet work!!!
Thomas
2bits
2bit Member
Postby myoung » Fri Mar 18, 2011 11:19 pm
Time to install some plumbing. Here is a photo of the underside of the trailer showing the discharge pipe from the 17-gallon grey water tank thru a ball valve and out a hose bib fitting. There is about 7 inches of clearance above the ground.
The grey water tank is suspended on four 8-inch carriage bolts fastened to angles. The fit couldn't have worked out better.
Now that the deflector detail has been worked out, I was able to locate the lower attachment point for the linear actuator. Here is the actuator in the fully-extended (18-inch throw) position.
Here's the actuator seen from the inside. The rocker switch to move it up and down is shown on the electrical panel on the far right. It's kind of a touchy little switch that will take some getting used to.
Here is the slot in which the actuator travels fore and aft. With two hinges at the back of the pop-up and this narrow slot at the front, there is little or no side to side movement. I think this will work out well when finished.
Mike Young
myoung
Images: 250
Postby emiller » Sat Mar 19, 2011 9:00 am
Boy Mike you sure have a sharp mind and are doing fantastic work. Is the Airstream feeling neglected.
emiller
Images: 157
Postby myoung » Sat Mar 19, 2011 9:35 am
emiller wrote: Is the Airstream feeling neglected.
Not really. Airstreams know that they are around for forever. May take it out to a rally at Lake Pleasant in mid-April.
Mike Young
myoung
Images: 250
Postby starleen2 » Sat Mar 19, 2011 12:49 pm
you just raised the "coolness" factor with the linear actuator (pun intended) :thumbsup:
starleen2
5th Teardrop Club
Postby bve » Sat Mar 19, 2011 1:19 pm
The trailer is coming along nicely, great pictures and detail.
I'm wondering what your plan is for sealing the opening for the actuator?
Burke
KISS > COMPLEX
Build threads converted to PDFs.
As of 2008-08-08 I have added more build threads to the pdf collection
bve
Images: 98
Postby myoung » Sat Mar 19, 2011 2:00 pm
bve wrote:I'm wondering what your plan is for sealing the opening for the actuator?
Me too. Stay tuned. I'm certain that the solution will reveal itself.
Mike Young
myoung
Images: 250
Postby Cliffmeister2000 » Sat Mar 19, 2011 5:52 pm
It will be under the canvas, won't it?
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
Postby S. Heisley » Sat Mar 19, 2011 7:53 pm
:thinking: Very Interesting. I'm looking forward to seeing more!
Postby myoung » Sat Mar 19, 2011 10:54 pm
More framing of the deflector. Lots of wood for such a small item but it had to be done for support and stability.
Notice that the slotted opening for the deflector unit is actually quite small. The length of travel is only about 3 1/2 inches and the hinges together with the linear actuator are sufficient to restrain the potential side-to-side motion. This photo shows the fully extended position.
Here are two images of the small slotted opening. This shouldn't be too hard to cover with a piece of rubber or a moveable flap. This is the completely down position.
This is the opening in the fully-retracted position.
Mike Young
myoung
Images: 250
Postby myoung » Sat Mar 19, 2011 11:01 pm
Cliffmeister2000 wrote:It will be under the canvas, won't it?
Yes, Cliff, the canvas (or rip stop nylon) would be attached to the inside lip of the pop-up and the outside lip of the actual roof opening.
Mike Young
myoung
Images: 250
